Sensor mode converts the radio to a sensor for ADSP and Positioning. The AP4xx access point models offer a third radio that is a separate sensor radio. For more information, see Radio as a Sensor.
Only one radio can be configured for Client Bridge. All traffic received by the client bridge AP over wired port or by the remaining radios is forwarded to the infrastructure network via the client bridge radio.| AP Model | Radio 1 | Radio 2 | Radio 3 |
| AP3000/X | 2.4GHz /6GHz (dual band)
| 5GHz
| AP302W | 2.4GHz /5GHz (dual band)
| 5GHz
Note: 160
MHz channel width not supported.
| AP305C/CX | 2.4GHz
/5GHz (dual band)
| 5GHz
Note: 160
AP305C must configure sensor for both radios together. | |
Note: AP305C/CX offers a single port. When Client Bridge is configured on a single interface AP, the single
interface is used as the client port, not as an uplink, and you will not see the
GE2 Port Function field in the configuration Profile
Advanced Settings.
The ETH1/GE2 Bridge port is not supported on access points with a
single Ethernet port.
| 2.4GHz /5GHz (dual
band)
| 5GHz
Note: 160
| AP360i/e | 2.4GHz /5GHz (dual
band)
| 5GHz
Note: 160
| 2.4GHz
| 5GHz
| 6GHz/Sensor
| 2.4GHz
| 5GHz
| Sensor
| 2.4GHz
/5GHz
| 5GHz
| Sensor
| AP460e | 2.4GHz
| 5GHz
| Sensor
| AP460C/S6C/S12C | 2.4GHz/ 5GHz
| 5GHz
| Sensor
| AP5010 | 2.4GHz/ Tri-band Sensor, supports
2.4GHz wireless service, or a tri-band sensor
| 5GHz
| 6GHz
| AP5020 | 2.4GHz/ Tri-band Sensor, supports 2.4GHz
| 5GHz
| 6GHz
Note: For AP5020, indicate the Operating
Mode. Based on selected operating mode, the
Radios field is updated. Radio mode
selection depends on Operating
Mode. For example, when operating mode is 2.4/5/6
GHz Service, the Radio configuration on the profile
allows 2.4 GHz modes for Radio 1, 5 GHz modes for Radio 2,
and 6 GHz modes for Radio 3.
| AP5050U AP5050D | 2.4GHz/ Tri-band Sensor, supports
| 5GHz
| 6GHz (Not currently supported for regulatory compliance)
| AP505i | 2.4GHz
| 5GHz
| 5GHz
| AP560i/h | 2.4GHz /5GHz (dual
band)
| 5GHz
| AP39xx | 5GHz
| 2.4GHz
