Extreme Scheduler
Schedule network services and reports with Scheduler for ExtremeCloud IQ Controller.
Scheduler for ExtremeCloud IQ Controller is installed as a container application on the ExtremeCloud IQ Controller. The application runs and is upgraded independently from the appliance. Before accessing Scheduler application, you must generate an API key from ExtremeCloud IQ Controller and upload it to the controller. Subsequent upgrades can use the previously installed API key file.
ExtremeCloud IQ Controller offers a default configuration template for Scheduler application. This template cannot be modified.
Scheduler for ExtremeCloud IQ Controller is available on the Extreme Networks Support site.
To install Scheduler for ExtremeCloud IQ Controller:
  1. Download and install the Docker application.
  2. Generate the API key.
  3. Associate the API key with the Docker application.
    When running more than one ExtremeCloud IQ Controller application that uses an API key file, you need only one generated API key.
  4. Start the application.
