Use Table 98 to customize your captive portal.
| Setting | Description |
| Display Powered by Logo | Display the Extreme Networks logo at the bottom of all of your portal web pages. |
| Edit Message String | Modify the message displayed to users on the menu bar of any registration or web access page. The default welcome message is "Welcome to the Enterprise Network's Registration Center." |
| Edit Images | Specify the image
files used in the portal web pages. All image files must be defined here. Select the
plus sign to add images. After the image is added, select Note: You must add images
to each portal separately. Images listed under the default portal are not
available to other portals until you have added the image to each portal
separately.
| Edit Colors | Select the
Background or Text color box corresponding to each item to open the Choose Color window.
Define the colors used in the portal web pages:
| Edit Style Sheets | Create a style sheet that adds to or overwrites the formatting styles for the portal, or mobile version of the portal web pages, respectively. |
| Edit Locales | Define the default
locale (language), displayed to any captive portal user unless the client locale
detected from their browser matches one of the defined supplemental locales. The
list of available locales includes the current default locale and any supplemental
defined locales. Display Locale Selector — Select this check box if you want a locale (language) selector to display as a drop-down menu in the menu bar on the captive portal welcome and login pages. This is useful for a shared machine where the users of the machine may speak different languages. On the mobile captive portal, the selector is displayed as a list of links at the bottom of the welcome screen. Add — Add a locale to the list of possible locales. Select a
Language
Bundle value, and the other parameters will auto populate.
To delete a locale, select |
