To modify settings for an access point (AP) and its radio properties:
The AP must be part of a device group before the radio settings and the Professional Install button are displayed. To add an AP to a device group, see Add APs.Field | Description |
Radio Band Title | The
title indicates the radio band and if the radio is
configured for Mesh or Client Bridge. Note: Mesh and
Client Bridge cannot be configured on the same
AP.
Use RF Management Policy | Indicates if
settings from the RF Management policy that is associated
with the device group are used. Valid values:
Mesh: Mesh Radio configuration supports Fixed Channel for root APs and Mesh ACS for non-root APs. See Configure a Mesh Point Network for more information about configuring a Mesh Network. |
Channel Width | Determines the channel width for the
radio. Valid values are:
Select |
Request New Channel | Specifies the primary channel of the wireless AP. Depending on the licensed regulatory domain, channels may be restricted. ACS in the 2.4 GHz radio band with 40 MHz channels is not recommended due to severe co-channel interference. |
Max Tx Power | Determines the maximum power level that can be used by the radio in dBm. The values are governed by compliance requirements based on the country, radio, and antenna selected, and will vary by AP. |
Fallback Channel(s) | You can configure the fallback channel in case the main channel is unavailable. The system logs when APs are operating with the fallback channel so that administrators are aware the primary channel is not in use. First,
hover the mouse pointer over the information icon Specify a 5GHz channel that the radio will adopt if DFS fails. ExtremeWireless APs support up to 9 channels. The following
setting is supported on ExtremeWireless access
point models Wi-Fi 6 AP models
that are configured for a Centralized site.
Note: DFS is not recommended on a radio
configured for Mesh.
For Automatic Frequency Coordination (AFC): You can configure the fallback channel in case the main channel is removed by the AFC server. Only one AFC Fallback Channel can be selected at at time. Specify a 6GHz backup channel that the radio will adopt if AFC fails. If the primary channel becomes available again, the AP returns to the primary channel. If the backup channel is also unavailable, then the AP transitions to "RADIO OFF due to compliance." |
