| Field Name | Field Description |
| In the Capture Locations pane, configure the following settings: | |
| Appliance Data Ports | Select this option to capture packets to and from the appliance. When capturing
appliance data ports, you must configure at least one filter. From the Add Filters field, select
either IP address or MAC address for the appliance. Only one capture task can apply to the Appliance Data Ports at a time. If more than one capture task is started using the Appliance Data Ports, the last requested task will be started. |
| Wired | Enables wired-packet capture on the selected AP. Filter packets on the basis of the direction of packet flow:
Select Includes Wired Clients to include wired-packets received and transmitted to and from wired clients associated with the selected AP. This option is disabled by default. |
| Wireless | Enables wireless-packet capture on the selected AP. Filter packets on the basis of the direction of packet flow:
Specify the radio interface on which to enable wireless-packet capture.
Note: AP39xx, Wi-Fi 6 AP models (Centralized site) support
capturing wired and wireless packets simultaneously. The result is one PCAP file
that includes both wired and wireless packets.
| In the Settings pane, specify how you want to determine the length of the packet capture. Specify the duration or manually end packet capture by clicking Stop. | |
| Duration | Packet transfer window. Default value is 5 minutes. |
| Truncate Packet Size (Bytes) | Number of bytes for the truncated packet. When truncation is configured, the
capture collects up to the configured size of the payload (including the IP/UDP/TCP
headers). Note: TZSP header is always present. If the truncated packet size is zero,
the TZSP header remains in the packet.
| In the Filter pane, filter
packets by MAC address, IP address, IP Protocol, or Port. The filters are mutually
exclusive and are applied in the order in which they are listed. Enter at least one
MAC address or IP address. Note: Excessive packet capture degrades network performance. If you are going to enable
packet capture on all APs, specify at least one MAC address filter and one IP
address filter to avoid performance degradation.
| Filter by MAC 1 and Filter by MAC 2 | Specify one or two MAC addresses to filter packets for capture. When a MAC address is specified, only packets that move to and from the specified MAC addresses are captured. Support for multiple MAC addresses depends on the AP model. |
| Filter by IP 1 to Filter by IP 4 | Specify one to four IP addresses to filter packets for capture. When an IP address is specified, only packets that move to and from the specified IP addresses are captured. Both IPv4 and IPv6 address formats are supported. Support for multiple IP addresses depends on the AP model. When using multiple IP address filters, packets matching any of the IP addresses are captured. |
| IP Protocol | Specify the protocol to filter for packet capture. Packets matching the specified
protocol are captured. Valid values are:
| Port | Specify a TCP or UDP port number. Packets with the matching port number are captured. Use Port as an additional filter, or if you wish to specify a protocol that is not included in the IP Protocol menu. |
| Packet Destination | Capture Destination. Valid values are:
Note: Each capture instance is
assigned one local file. All active capture instances must use the same SCP
server.
| Export |
Note: Hover over the PAC file to download. Certain APs support capturing wired and
| Active Packet Captures | Select Active Packet
Captures to display the dashboard where you can view Packet Capture
Instances. To add the Packet Capture Instances widget to your dashboard:
