Binds an EX3500 ACL to the selected port
When applied to the port, the ACL takes effect. Only one ACL can be bound to a port at a time. In case you bind a new ACL to a port with an existing ACL binding, the old binding is replaced with the new one.
access-group [ex3500-ext-access-list|ex3500-std-access-list|mac-access-list] <ACL-NAME> in {time-range <TIME-RANGE-NAME>}
| access-group | Binds a EX3500 ACL with this GE port. Select ACL type and specify the ACL name. The ACL should be existing and configured. |
| ex3500-ext-access-list <ACL-NAME> | Binds an existing and configured EX3500 extended ACL
| ex3500-std-access-list <ACL-NAME> | Binds an existing and configured EX3500 standard ACL
| mac-access-list <ACL-NAME> | Binds an existing and configured EX3500 MAC ACL
| in | Applies the specified ACL to all incoming packets |
| time-range <TIME-RANGE-NAME> | Optional. Associates a EX3500 absolute or periodic time range with this access group. The specified ACL is bound to the port during the time period specified by the associated time range.
nx9500-6C8809(config-profile-testEX3524-if-ge1-20)#access-group ex3500-ext-access-list EX3500_ACL_EXT_1 in time-range EX3500_TimeRange_01 nx9500-6C8809(config-profile-testEX3524-if-ge1-20)#show context interface ge 1 20 access-group ex3500-ext-access-list EX3500_ACL_EXT_1 in time-range EX3500_TimeRange_01 nx9500-6C8809(config-profile-testEX3524-if-ge1-20)#
| no | Removes the GE port EX3500 ACL binding |
