| Command | Description |
| deny (ex3500-std acl) | Creates a deny rule that rejects packets from a specified source or sources. The source can be a single device or a range of devices within a specified network. Use this command to also edit an existing deny rule. |
| permit (ex3500-std acl) | Creates a permit rule that allows packets from a specified source or sources. The source can be a single device or a range of devices within a specified network. Use this command to also edit an existing permit rule. |
| no (ex3500-std acl) | Removes a deny and/or a permit access rule from this IPv4 EX3500 extended ACL |
To implement the EX3500 standard ACL, apply it directly to a EX35XX device, or to an EX35XX profile. For more information, see access-group.
