Configures the tunnel's local router ID
router-id [<1-4294967295>|<IP>]
router-id [<1-4294967295>|<IP>] |
Configures the tunnel's local router ID in one of the following formats:
nx9500-6C8809(config-profile default-rfs4000-l2tpv3-tunnel-Tunnel1)#router-id 2000
nx9500-6C8809(config-profile default-rfs4000-l2tpv3-tunnel-Tunnel1)#show context l2tpv3 tunnel Tunnel1 peer 2 hostname tunnel1peer1 udp port 100 router-id 2000 establishment-criteria cluster-master nx9500-6C8809(config-profile default-rfs4000-l2tpv3-tunnel-Tunnel1))#
Removes the tunnel's router ID |
