Configures the third-party, BLE-locationing server‘s URL. This is the external resource to which WiNG APs forward BLE data (UUID, RSSI, etc.) using the REST API. The data is forwarded in the JASON format.
Access Points — AP-7612, AP7632, AP7662, AP-8432, AP-8533
Wireless Controllers — RFS 4000
Service Platforms — NX 5500, NX 75XX, NX 95XX, NX 96XX, VX 9000
rest <URL>
rest <URL>
rest <URL> |
Configures the third-party server's URL
ap8432-070235(config-ble-data-export-policy-test)#rest https://test.com/12/
ap8432-070235(config-ble-data-export-policy-test)#show context ble-data-export-policy test rest https://test.com/12/ ap8432-070235(config-ble-data-export-policy-test)#
The following example shows the configurations will have to configure the following parameters to enable BLE data forwarding:
On the WiNG AP‘s profile/device context, configure the following Bluetooth parameters:
ap8432-070235(config-profile-test-if-bluetooth1)#mode le-sensor
ap8432-070235(config-profile-test-if-bluetooth1)#no shutdown
ap8432-070235(config-profile-test-if-bluetooth1)#show context interface bluetooth1 no shutdown mode le-sensor ap8432-070235(config-profile-test-if-bluetooth1)#
This enables the AP as a BLE sensor.
On the APs‘ controller,
Configure a BLE data export policy, pointing to the external, third-party, REST end-point.
NOC-NX9500(config-ble-data-export-policy-test)#rest https://test.com/12/
Configure a sensor policy.
NOC-NX9500((config-sensor-policy-test)#rssi-interval-duration 30
Navigate to the BLE-enabled, WiNG AP‘s RF Domain context and:
Use the BLE data export policy, configured in step 2a.
NOC-NX9500(config-rf-domain-ble)#use ble-data-export-policy test
This enables BLE data forwarding to the external, third-party server specified in the policy.
Use the sensor policy, configured in step 2b.
NOC-NX9500(config-rf-domain-ble)#use sensor-policy test
When applied, BLE data is forwarded at the interval specified in the sensor policy.
Removes the REST endpoint URL configuration |
Documents AP profile/device Bluetooth interface configuration commands |
Documents the Sensor policy configuration commands |
Applies the ‘BLE data export policy‘ and ‘Sensor policy‘ on the RF Domain |
