Adds deny device adoption rules to the Auto Provisioning Policy
deny [anyap|ap6522|ap6562|ap71xx|ap7502|ap7522|ap7532|ap7562|ap7602|ap7612|ap7622|ap7632| ap7662|ap81xx|ap8432|ap8533|rfs4000|nx5500|nx75xx|nx9000|vx9000|nx9600]
deny [anyap|ap6522|ap6562|ap71xx|ap7502|ap7522|ap7532|ap7562|ap7602|ap7612|ap7622|ap7632| ap7662|ap81xx|ap8432|ap8533|rfs4000|nx5500|nx75xx|nx9000|vx9000|nx9600] precedence <1-10000> [any|cdp-match|dhcp-option|fqdn|ip|ipv6|lldp-match|mac|model-number|serial-number|vlan]
deny [anyap|ap6522|ap6562|ap71xx|ap7502|ap7522|ap7532|ap7562|ap7602|ap7612|ap7622|ap7632| ap7662|ap81xx|ap8432|ap8533|rfs4000|nx5500|nx75xx|nx9000|vx9000|nx9600] precedence <1-10000> any
[cdp-match <LOCATION-SUBSTRING>|dhcp-option <DHCP-OPTION>|fqdn <FQDN>|ip [<START-IP> <END-IP>|
<IP/MASK>]|ipv6 [<START-IP> <END-IP>|<IP/MASK>]|lldp-match <LLDP-STRING>|
mac <START-MAC> {<END-MAC>}|model-number <MODEL-NUMBER>|serial-number <SERIAL-NUMBER>|
vlan <VLAN-ID>]
deny |
Adds a deny adoption rule. The rule applies to
the selected device types. Specify the device type and assign a precedence
to the rule. The different device types are: AP 6522, AP 6562, AP 7161, AP 7502, AP-7522, AP 7532, AP 7562, AP 7602, AP-7612, AP 7622, AP7632, AP7662, AP-8163, AP-8432, AP-8533, RFS 4000, NX 5500, NX 75XX, NX 95XX, NX 96XX, and VX. Note: Use the ‘anyap‘
option to auto provision any AP regardless of its model
type.
precedence <1-10000> |
Sets the rule precedence. A rule with a lower value has a higher precedence. |
any |
Indicates any device. Any device seeking adoption is denied adoption. |
<IP/MASK>]|ipv6 [<START-IP> <END-IP>|<IP/MASK>]|lldp-match <LLDP-STRING>|mac <START-MAC>
{<END-MAC>}|model-number <MODEL-NUMBER>|serial-number <SERIAL-NUMBER>|vlan <VLAN-ID>]
adopt |
type.
Sets the rule precedence. A rule with a lower value has a higher precedence. After specifying the rule precedence, specify the match criteria. Devices matching the specified criteria are denied adoption. |
| cdp-match <LOCATION-SUBSTRING> | Matches a substring in a list of CDP snoop
strings (case insensitive). For example, if an access point snooped 3
devices: controller1.example.com, controller2.example.com, and
controller3.example.com, 'controller1', ‘example‘, 'example.com', are
examples of the substrings that will match.
| dhcp-option <DHCP-OPTION> | Matches the value found in DHCP vendor option 191
(case insensitive). DHCP vendor option 191 can be setup to communicate
various configuration parameters to an AP. The value of the option in a
string in the form of tag=value separated by a semicolon, for example
'tag1=value1;tag2=value2;tag3=value3'. The access point includes the value
of tag 'rf-domain', if present.
fqdn <FQDN> |
Matches a substring to the FQDN of a device (case insensitive) FQDN is a domain name that specifies its exact location in the DNS hierarchy. It specifies all domain levels, including its top-level domain and the root domain.
ip [<START-IP> <END-IP>| <IP/MASK>] |
Denies adoption if a device's IP address matches
the specified IPv4 address or is within the specified IP address range
| ipv6 [<START-IP> <END-IP>| <IP/MASK>] | Denies adoption if a device's IPv6 address
matches the specified IP address or is within the specified IP address
range
lldp-match <LLDP-STRING> |
Matches a substring in a list of LLDP snoop strings (case insensitive). For example, if an Access Point snooped 3 devices: controller1.example.com, controller2.example.com and controller3.example.com,'controller1', 'example', 'example.com', are substrings match. LLDP is a vendor neutral link layer protocol that advertises a network device‘s identity, capabilities, and neighbors on a local area network.
mac <START-MAC> {<END-MAC>} |
Denies adoption if a device's MAC address matches
the specified MAC address or is within the specified MAC address range
model-number <MODEL-NUMBER> |
Denies adoption if a device‘s model number
matches <MODEL-NUMBER>
serial-number <SERIAL-NUMBER> |
Denies adoption if a device‘s serial number
matches <SERIAL-NUMBER>
vlan <VLAN-ID> |
Denies adoption if a device‘s VLAN matches
<VLAN-ID>
rfs4000-229D58(config-auto-provisioning-policy-test)#deny ap8432 precedence 1 mac 74-67-F7-07-02-35
rfs4000-229D58(config-auto-provisioning-policy-test)#deny ap8432 precedence 2 ip 192.168.13.24 102.168.13.26
rfs4000-229D58(config-auto-provisioning-policy-test)#show context auto-provisioning-policy test default-adoption deny ap8432 precedence 1 mac 74-67-F7-07-02-35 deny ap8432 precedence 2 ip 192.168.13.24 102.168.13.26 adopt ap8432 precedence 5 profile default-ap8432 rf-domain TechPubs vlan 1 rfs4000-229D588(config-auto-provisioning-policy-test)#
| no |
Removes a deny adoption rule from this Auto Provisioning Policy |
