Configures L2TPV3 tunnel establishment criteria
A L2TPV3 tunnel is established from the current device to the NOC Controller when the current device becomes the VRRP master, cluster master, or RF Domain Manager. Similarly, the L2TPV3 tunnel is closed when the current device switches to standby or backup mode.
establishment-criteria [always|cluster-master|rf-domain-manager|vrrp-master <1-255>]
always |
Always establishes a L2TPv3 tunnel from the current device to the NOC controller. This is the default setting. The ‘always‘ option indicates the device need not be a cluster-master, rf-domain-manager, or vrrp-master to establish a tunnel. |
cluster-master |
Establishes a L2TPv3 tunnel from the current device to the NOC controller, only when the current device becomes the cluster master Note: The l2TPV3 tunnel is closed when the current device switches back the
rf-domain-manager |
Establishes a L2TPv3 tunnel from the current device to the NOC controller, only when the current device becomes the RF Domain manager Note: The l2TPV3 tunnel is closed when the current device switches back the
vrrp-master <1-255> |
Establishes a L2TPv3 tunnel from the current device to the NOC controller, only when the current device becomes the VRRP master
Note: The L2TPV3 tunnel is closed when the current device switches back the
nx9500-6C8809(config-profile default-rfs4000-l2tpv3-tunnel-Tunnel1)#establishment-criteria
cluster-master
nx9500-6C8809(config-profile default-rfs4000-l2tpv3-tunnel-Tunnel1)#show context l2tpv3 tunnel Tunnel1 establishment-criteria cluster-master nx9500-6C8809(config-profile default-rfs4000-l2tpv3-tunnel-Tunnel1)#
| no |
Resets to default (always) |
