use (meshpoint-config)
Uses a QoS (Quality of Service)
policy defined specifically for meshpoints. To use this QoS policy, it must be
defined.
- Access Points — AP7502, AP7522,
AP7532, AP7562, AP7602, AP7612, AP7622, AP7632, AP7662, AP8163, AP8432, AP8533
- Wireless Controller — RFS4010
- Service Platforms — NX5500, NX7500,
NX9500, NX9600, VX9000
Syntax
use [aaa-policy <AAA-POLICY-NAME>|meshpoint-qos-policy <MESHPOINT-QOS-POLICY-NAME>]
Parameters
<MESHPOINT-QOS-POLICY-NAME> |
Configures this meshpoint to use a predefined
meshpoint QoS policy
- <MESHPOINT-QOS-POLICY-NAME> – Specify the meshpoint QoS policy
name (should be existing and configured).
| aaa-policy <AAA-POLICY-NAME> |
aaa-policy
- <AAA-POLICY-NAME> – Specify the aaa-policy name (should be
nx9500-6C8809(config-meshpoint-test)#use meshpoint-qos-policy test
nx9500-6C8809(config-meshpoint-test)#show context
meshpoint test
description "This is an example of a meshpoint description"
meshid TestingMeshPoint
shutdown
beacon-format mesh-point
control-vlan 1
allowed-vlans 1,10-16,18-23
neighbor inactivity-timeout 300
data-rates 2.4GHz bgn
data-rates 5GHz an
security-mode psk
root
