rssi-interval-duration <1-60>
| rssi-interval-duration <1-60> | Configures the RSSI interval duration in seconds. This is the interval at which
the sensor scans channels for RSSI data and forwards the data to a dedicated server
resource. The server calculates real-time locations of Wi-Fi devices based on the
this data.
The channels scanned for RSSI assessment depends on the scan-mode selected. For more information, see scan-mode and custom-scan. Ensure that the server‘s IP address or hostname has been configured in the access point sensor‘s RF Domain context. |
nx9500-6C8809(config-sensor-policy-test)#rssi-interval-duration 30
nx9500-6C8809(config-sensor-policy-test)#show context sensor-policy test rssi-interval-duration 30 scan-mode Custom-Scan custom-scan channel-frequency 2412 width 20MHz scan-weight 1000 custom-scan channel-frequency 2417 width 20MHz scan-weight 1000 nx9500-6C8809(config-sensor-policy-test)#
| no (sensor-policy-config-mode-commands) | Resets the interval at which RSSI data is collected and sent by the sensor to the MPact server host to default (1 second) |
