Removes device overrides in order to enable profile settings to take effect
remove-override <PARAMETERS>
| remove-override <PARAMETERS> | Removes settings configured at the device level based on the parameters passed. The profile (applied to the device) settings take effect once the device-level overrides are removed. |
nx9500-6C8809(config-device-B4-C7-99-6C-88-09)#remove-override ?
adopter-auto-provisioning-policy-lookup Use centralized auto-provisioning
policy when adopted by another
controller
adoption Adoption configuration
adoption-mode Configure the adoption mode for the
access-points in this RF-Domain
alias Alias
all Remove all overrides for the device
application-policy Application Policy configuration
area Reset name of area where the system
is located
arp Address Resolution Protocol (ARP)
auto-learn Auto learning
autogen-uniqueid Autogenerate a unique id
autoinstall Autoinstall settings
bridge Bridge group commands
captive-portal Captive portal
cdp Cisco Discovery Protocol
channel-list Configure a channel list to be
advertised to wireless clients
cluster Cluster configuration
configuration-persistence Automatic write of startup
configuration file
contact The contact
controller WLAN controller configuration
country-code The country of operation
critical-resource Critical Resource
crypto Encryption related commands
database Database command
device-upgrade Device firmware upgrade
diag Diagnosis of packets
dot1x 802.1X
dpi Deep-Packet-Inspection (Application
Assurance)
dscp-mapping IP DSCP to 802.1p priority mapping
for untagged frames
eguest-server Configure ExtremeGuest server
email-notification Email notification configuration
encrypted-alias Alias
enforce-version Check the firmware versions of
devices before interoperating
environmental-sensor Environmental Sensors Configuration
events System event messages
export Export a file
file-sync File sync between controller and
adoptees
firewall Enable/Disable firewall
floor Reset name of floor where the
system is located
geo-coordinates Geo co-ordinates for this device
global Remove global overrides for the
device but keeps per-interface
overrides
gre GRE protocol
interface Select an interface to configure
ip Internet Protocol (IP)
ipv6 Internet Protocol version 6 (IPv6)
l2tpv3 L2tpv3 protocol
l3e-lite-table L3e lite Table
led LED on the device
lldp Link Layer Discovery Protocol
location The location
location-policy Location policy configuration
location-server ExtremeLocation server
configuration
location-tenantid ExtremeLocation tenant account
configuration
logging Modify message logging facilities
mac-address-table MAC Address Table
mac-auth 802.1X
management-server Configure management server address
memory-profile Memory-profile
mint MiNT protocol
noc Noc related configuration
nsight-sensor NSIGHT sensor configuration
ntp Configure NTP
offline-duration Duration to mark adopted device as
offline
override-wlan Overrides for wlans
power-config Configure power mode
preferred-controller-group Controller group this system will
prefer for adoption
preferred-tunnel-controller Tunnel Controller Name this system
will prefer for tunneling extended
vlan traffic
remote-debug Configure remote debug parameters
rf-domain-manager RF Domain Manager
router Dynamic routing
routing-policy Policy Based Routing Configuration
sensor-server AirDefense WIPS sensor server
configuration
spanning-tree Spanning tree
timezone The timezone
traffic-class-mapping IPv6 traffic-class to 802.1p
priority mapping for untagged
frames
traffic-shape Traffic shaping
trustpoint Assign a trustpoint to a service
tunnel-controller Tunnel Controller group this
controller belongs to
use Set setting to use
vrrp VRRP configuration
ws-controller Configure websocket controller
zone Configure Zone name
service Service Commands
