l2tpv3-tunnel-commands
Use the (profile or device context)
instance to configure a L2TPv3 tunnel. To navigate to the tunnel configuration mode, use
the following command in the profile
context:<DEVICE>(config-profile-default-<device-name>)#l2tpv3 tunnel <TUNNEL-NAME>
nx9500-6C8809(config-profile-default-rfs4000)#l2tpv3 tunnel Tunnel1
nx9500-6C8809(config-profile default-rfs4000-l2tpv3-tunnel-Tunnel1)#
nx9500-6C8809(config-profile default-rfs4000-l2tpv3-tunnel-Tunnel1)#?
L2tpv3 Tunnel Mode commands:
establishment-criteria Set tunnel establishment criteria
fast-failover Configure fast failover for l2tpv3 tunnels
hostname Tunnel specific local hostname
local-ip-address Configure the IP address for tunnel. If not
specified, tunnel source ip address would be chosen
automatically based on the tunnel peer ip address
mtu Configure the mtu size for the tunnel
no Negate a command or set its defaults
peer Configure the l2tpv3 tunnel peers. At least one peer
must be specified
preempt Preemption of secondary tunnel when primary comes
back
router-id Tunnel specific local router ID
session Create / modify the specified l2tpv3 session
use Set setting to use
clrscr Clears the display screen
commit Commit all changes made in this session
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
The following table summarizes L2TPV3
tunnel configuration commands:
Table 1. L2TPV3-Tunnel-Config
Commands
Command |
Description |
Configures L2TPV3 tunnel establishment criteria |
fast-failover |
Configures fast-failover support on the L2TPv3 tunnel |
hostname
Configures tunnel specific local hostname |
local-ip-address
Configures the tunnel's IP address |
mtu
Configures the tunnel's MTU (Maximum Transmission Unit)
size |
peer
Configures the tunnel's peers |
preempt |
Enables preemption of secondary tunnel when primary tunnel comes
back. And, configures the interval after which the the secondary tunnel
is preempted. |
router-id
Configures the tunnel's local router ID |
session |
Creates/modifies specified L2TPV3 session |
use |
Configures a tunnel to use a specified L2TPV3 tunnel policy |
no (l2tpv3-tunnel-config-mode-command) |
Removes this L2TPv3 tunnel settings or reverts them to default
value |
