access-group
interface-ge-config commands
Binds an EX3500 ACL to the selected port
When applied to the port, the ACL takes effect. Only one ACL can be bound to a port at a time. In case you bind a new ACL to a port with an existing ACL binding, the old binding is replaced with the new one.
Syntax
access-group [ex3500-ext-access-list|ex3500-std-access-list|mac-access-list] <ACL-NAME> in {time-range <TIME-RANGE-NAME>}
Parameters
access-group Binds a EX3500 ACL with this GE port. Select ACL type and specify the ACL name. The ACL should be existing and configured.
ex3500-ext-access-list <ACL-NAME> Binds an existing and configured EX3500 extended ACL
  • <ACL-NAME> – Specify the ACL name.
ex3500-std-access-list <ACL-NAME> Binds an existing and configured EX3500 standard ACL
mac-access-list <ACL-NAME> Binds an existing and configured EX3500 MAC ACL
  • <ACL-NAME> – Specify the MAC ACL name.
in Applies the specified ACL to all incoming packets
time-range <TIME-RANGE-NAME> Optional. Associates a EX3500 absolute or periodic time range with this access group. The specified ACL is bound to the port during the time period specified by the associated time range.
  • <TIME-RANGE-NAME> – Specify the time range name (should be existing and configured).
nx9500-6C8809(config-profile-testEX3524-if-ge1-20)#access-group ex3500-ext-access-list EX3500_ACL_EXT_1 in time-range EX3500_TimeRange_01
nx9500-6C8809(config-profile-testEX3524-if-ge1-20)#show context
 interface ge 1 20
Related Commands
no Removes the GE port EX3500 ACL binding
