upgrade [anyap|ap6522|ap6562|ap71xx|ap7502|ap7522|ap7532|ap7562|ap7602|ap7612| ap7622|ap7632|ap7662|ap81xx|ap8432|ap8533|rfs4000|nx5500|nx75xx|nx95xx|vx9000|nx96xx]
upgrade [anyap|ap6522|ap6562|ap71xx|ap7502|ap7522|ap7532|ap7562|ap7602|ap7612| ap7622|ap7632|ap7662|ap81xx|ap8432|ap8533|rfs4000|nx5500|nx75xx|nx95xx|vx9000|nx96xx] precedence <1-10000> [any|cdp-match|dhcp-option|fqdn|ip|ipv6|lldp-match|mac|model-number| serial-number|vlan]
upgrade [anyap|ap6522|ap6562|ap71xx|ap7502|ap7522|ap7532|ap7562|ap7602|ap7612| ap7622|ap7632|ap7662|ap81xx|ap8432|ap8533|rfs4000|nx5500|nx75xx|nx95xx|vx9000|nx96xx] precedence <1-10000> any
upgrade [anyap|ap6522|ap6562|ap71xx|ap7502|ap7522|ap7532|ap7562|ap7602|ap7612| ap7622|ap7632|ap7662|ap81xx|ap8432|ap8533|rfs4000|nx5500|nx75xx|nx95xx|vx9000|nx96xx] precedence <1-10000> [cdp-match <LOCATION-SUBSTRING>|dhcp-option <DHCP-OPTION>|fqdn <FQDN>| ip [<START-IP> <END-IP>|<IP/MASK>]|ipv6 [<START-IP> <END-IP>|<IP/MASK>]| lldp-match <LLDP-STRING>|mac <START-MAC> {<END-MAC>}|model-number <MODEL-NUMBER>| serial-number <SERIAL-NUMBER>|vlan <VLAN-ID>]
upgrade | Adds a device upgrade rule. The rule applies to
the device type selected. Specify the device type and assign a precedence to
the rule. The different device types are: AP 6522, AP 6562, AP 7161, AP 7502, AP-7522, AP 7532, AP 7562, AP 7602, AP-7612, AP 7622, AP7632, AP7662, AP-8163, AP-8432, AP-8533, RFS 4000, NX 5500, NX 75XX, NX 95XX, NX 96XX, and VX. Note: Use the ‘anyap‘
option to auto provision any AP regardless of its model
type.
precedence <1-10000> | Sets the rule precedence. Rules with lower values get precedence over rules with higher values. |
any |
Indicates any device. Any device, of the selected type, is upgraded. |
upgrade |
type.
cdp-match <LOCATION-SUBSTRING> |
Configures the device location to match, based on CDP snoop strings
dhcp-option <DHCP-OPTION> |
Configures the DHCP options to match DHCP options identify the vendor and DHCP client functionalities. This information is used by the client to convey to the DHCP server that the client requires extra information in a DHCP response.
fqdn <FQDN> | Configures the FQDN to match. FQDN is a domain name that specifies its exact location in the DNS hierarchy. It specifies all domain levels, including its top-level domain and the root domain.
ip [<START-IP> <END-IP>|<IP/MASK>] | Upgrades if a device's IPv4 address matches the
specified IP address or is within the specified IP address range
ipv6 [<START-IP> <END-IP>| <IP/MASK>] | Upgrades if a device's IPv6 address matches the
lldp-match <LLDP-STRING> | Configures the device location to match, based on
LLDP snoop strings. LLDP is a vendor neutral link layer protocol used to advertise a network device‘s identity, capabilities, and neighbors on a local area network.
mac <START-MAC> {<END-MAC>} | Configures a single or a range of MAC addresses.
Devices matching the specified values are upgraded.
model-number <MODEL-NUMBER> | Configures the device model number
serial-number <SERIAL-NUMBER> | Configures the device‘s serial number
vlan <VLAN-ID> | Configures the VLAN ID
rfs4000-229D58(config-auto-provisioning-policy-test1)#upgrade ap8432 precedence 10 any
rfs4000-229D58(config-auto-provisioning-policy-test1)#upgrade ap7522 precedence 11 vlan 1
rfs4000-229D58(config-auto-provisioning-policy-test1)#show context auto-provisioning-policy test default-adoption evaluate-always deny ap8432 precedence 1 mac 74-67-F7-07-02-35 deny ap8432 precedence 2 ip 192.168.13.24 102.168.13.26 adopt ap8432 precedence 5 profile default-ap8432 rf-domain TechPubs vlan 1 redirect ap81xx precedence 6 controller 192.168.13.10 ip 192.168.13.11 192.168.13.15 redirect ap7532 precedence 7 controller 192.168.13.10 model-number AP-7532-67030-WR upgrade ap8432 precedence 10 any upgrade ap7522 precedence 11 vlan 1 rfs4000-229D58(config-auto-provisioning-policy-test1)#
no | Removes an upgrade rule from this Auto Provisioning Policy |
