Enables the insertion of a rule in an MAC ACL without overwriting or replacing an existing rule having the same precedence
The insert option allows a new rule to be inserted within a MAC ACL. Consider an MAC ACL consisting of rules having precedences 1, 2, 3, 4, 5, and 6. You want to insert a new rule with precedence 4, without overwriting the existing precedence 4 rule. Using the insert option inserts the new rule prior to the existing one. The existing precedence 4 rule‘s precedence changes to 5, and the change cascades down the list of rules within the ACL. That means rule 5 becomes rule 6, and rule 6 becomes rule 7.
NOT using insert when creating a new rule having the same precedence as an existing rule, overwrites the existing rule.insert [deny|permit] <PARAMETERS> (dot1p <0-7>,mark [8021p <0-7>|dscp <0-63>],
type [8021q|<1-65535>|aarp|appletalk|arp|ip|ipv6|ipx|mint|rarp|wisp],vlan <1-4095>,
log,rule-precedence <1-5000>) {(rule-description <LINE>)}
insert [deny|permit] |
Inserts a deny or permit rule within an MAC ACL |
<PARMETERS> |
Provide the match criteria for this deny/permit rule. Packets will be filtered based on the criteria set here. For more information on the deny rule, see deny. For more information on the permit rule, see permit. |
dotp1p <0-7> |
Configures the 802.1p priority value. Sets the service classes for traffic handling
mark [8021p <0-7>,dscp <0-63>] | Marks/modifies packets that match the criteria
specified here
Note: This option is applicable only to the MAC ACL permit
rule.
type [8021q|<1-65535>| aarp|appletalk| arp|ip|ipv6|ipx|mint| rarp|wisp] |
Configures the EtherType value An EtherType is a two-octet field in an Ethernet frame that indicates the protocol encapsulated in the payload of the frame. The EtherType values are:
vlan <1-4095> |
Configures the VLAN where the traffic is received
log |
Logs all deny/permit events matching this entry. If a source and/or destination MAC address is matched (i.e. a packet is received from a specified MAC address or is destined for a specified MAC address), an event is logged. |
rule-precedence <1-5000> rule-description <LINE> |
The following keywords are recursive and common to all of the above parameters:
Note: Lower the precedence higher is the priority. A rule with precedence 3
gets priority over a rule with precedence 10.
rfs4000-229D58(config-mac-acl-test1)#deny 11-22-33-44-55-66 11-22-33-44-55-77 any rule-precedence 1
rfs4000-229D58(config-mac-acl-test1)#deny host B4-C7-99-6D-CD-9B any rule-precedence 2
rfs4000-229D58(config-mac-acl-test1)#show context mac access-list test1 deny 11-22-33-44-55-66 11-22-33-44-55-77 any rule-precedence 1 deny host B4-C7-99-6D-CD-9B any rule-precedence 2 rfs4000-229D58(config-mac-acl-test1)#
In the following example a new rule is inserted between the rules having precedences 1 and 2. The precedence of the existing precedence ‘2‘ rule changes to precedence 3.
rfs4000-229D58(config-mac-acl-test1)#insert permit host B4-C7-99-6D-B5-D6 host B4-C7-99-6D-CD-9B rule-precedence 2
rfs4000-229D58(config-mac-acl-test1)#show context mac access-list test1 deny 11-22-33-44-55-66 11-22-33-44-55-77 any rule-precedence 1 permit host B4-C7-99-6D-B5-D6 host B4-C7-99-6D-CD-9B rule-precedence 2 deny host B4-C7-99-6D-CD-9B any rule-precedence 3 rfs4000-229D58(config-mac-acl-test1)#
