Displays the geographical coordinates (latitude and longitude) of the device for which the GPS coordinates search process has been triggered. The system displays the last recorded GPS coordinates of the device.
This feature is supported only on AP7662, which has a built-in, GPS hardware that starts and stops the GPS coordinates search process. To view the GPS coordinates of an AP7622, initiate GPS coordinates search and then execute the 'show > gps' command.
For more information on starting and stopping the GPS coordinate search process, see #GUID-9D132F11-ADE2-4B03-A35B-BFB1FE17C4D0.
AP 7622
show gps coordinates {on <DEVICE-NAME>}
show gps coordinates |
Displays the GPS coordinates of a device Note:
The command displays the last recorded GPS coordinates of the device. |
on <DEVICE-NAME> |
Optional. Specifies the name of the AP whose GPS coordinates are to be displayed. Use this option if executing the command on the controller or virtual controller to which the AP is adopted. Note:
If you do not specify a device name, the system initiates the search on the logged device. And if the logged device is not an AP7662 model access point, an error message returns. If |
ap7662-8BDE4D#show gps coordinates GPS Search is in progress. Last location recorded at UTC time : Mon Apr 23 22:10:54 2018 : Latitude : 13.036N Longitude : 77.3827E ap7662-8BDE4D#
