pfs
crypto-map-ipsec-isakmp-instance
Configures PFS (Perfect Forward Secrecy) for the auto site-to-site VPN tunnel or remote VPN client
PFS is the key-establishment protocol, used to secure VPN communications. If one encryption key is compromised, only data encrypted by that specific key is compromised. For PFS to exist, the key used to protect data transmissions must not be used to derive any additional keys. Options include 2, 5 and 14. This option is disabled by default.
Syntax
pfs [14|2|5]
Parameters
pfs [14|2|5]
pfs [14|2|5] Configures PFS
  • 14 – Configures D-H Group14 (2048-bit modp)
  • 2 – Configures D-H Group2 (1024-bit modp)
  • 5 – Configures D-H Group5 (1536-bit modp)
Site-to-site VPN tunnel:
rfs4000-229D58(config-device-00-23-68-22-9D-58-cryptomap-test#1)#pfs 5
rfs4000-229D58(config-device-00-23-68-22-9D-58-cryptomap-test#1)#show context
 crypto map test 1 ipsec-isakmp
  peer 1 ikev2 ikev2Peer1
  local-endpoint-ip 192.168.13.10
  pfs 5
  ip nat crypto
Remote VPN client:
rfs4000-229D58(config-device-00-23-68-22-9D-58-cryptomap-test#2)#pfs 14
rfs4000-229D58(config-device-00-23-68-22-9D-58-cryptomap-test#2)#show context
 crypto map test 2 ipsec-isakmp dynamic
  peer 1 ikev1 RemoteIKEv1Peer1
  local-endpoint-ip 157.235.204.62
  pfs 14
