local-endpoint-ip
crypto-map-ipsec-manual-instance
Uses the configured IP as local tunnel endpoint address, instead of the interface IP (Advanced Configuration)
Syntax
local-endpoint-ip <IP>
Parameters
local-endpoint-ip <IP> Uses the configured IP as local tunnel‘s endpoint address
  • <IP> – Specify the IP address. The specified IP address must be available on the interface.
nx9500-6C8809(config-profile-default-rfs4000-cryptomap-map1#1)#local-endpoint-ip 172.16.10.3
