Use the config-profile-<DEVICE-PROFILE-NAME> instance to configure Network Address Translation (NAT) pool settings.
The following example uses the config-profile-nx9500-6C8809 instance to configure NAT pool settings:
nx9500-6C8809(config-profile-default-rfs4000)#ip nat pool pool1 nx9500-6C8809(config-profile-default-rfs4000-nat-pool-pool1)# nx9500-6C8809(config-profile-default-rfs4000-nat-pool-pool1)#? Nat Policy Mode commands: address Specify addresses for the nat pool no Negate a command or set its defaults clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-profile-default-rfs4000-nat-pool-pool1)
The following table summarizes NAT pool configuration commands:
Command | Description |
address | Configures NAT pool addresses |
no | Negates a command or sets its default |
