Negates a command or resets configured settings to their default. When used in the radio QOS policy mode, the no command enables the resetting of accelerated multicast parameters, admission control parameters, and MultiMedia parameters.
no [accelerated-multicast|admission-control|smart-aggregation|wmm|service]
no accelerated-multicast [client-timeout|max-client-streams|max-streams| overflow-policy|stream-threshold]
no admission-control [firewall-detected-traffic|implicit-tspec|background| best-effort|video|voice]
no admission-control [firewall-detected-traffic|implicit-tspec]
no admission-control [background|best-effort|video|voice] {max-airtime-percent|
max-clients|max-roamed-clients|reserved-for-roam-percent}
no smart-aggregation {delay|max-mesh-hops|min-aggregation-limit}
no smart-aggregation {delay [background|best-effort|streaming-video|
video-conferencing|voice]|max-mesh-hops|min-aggregation-limit}
no wmm [background|best-effort|video|voice] [aifsn|cw-max|cw-min|txop-limit]
no service admission-control across-reassoc
no <PARAMETERS>
no <PARAMETERS> |
Negates a command or resets configured settings to their default. When used in the radio QOS policy mode, the no command enables the resetting of accelerated multicast parameters, admission control parameters, and MultiMedia parameters. |
The following example shows the Radio-qos-policy ‘test‘ settings before the ‘no‘ commands are executed:
nx9500-6C8809(config-radio-qos-test)#show context radio-qos-policy test admission-control voice max-airtime-percent 9 admission-control voice reserved-for-roam-percent 8 admission-control best-effort max-clients 200 accelerated-multicast stream-threshold 15 accelerated-multicast client-timeout 500 nx9500-6C8809(config-radio-qos-test)#
nx9500-6C8809(config-radio-qos-test)#no admission-control best-effort max-clients
nx9500-6C8809(config-radio-qos-test)#no accelerated-multicast client-timeout
The following example shows the Radio-qos-policy ‘test‘ settings after the ‘no‘ commands are executed:
nx9500-6C8809(config-radio-qos-test)#show context radio-qos-policy test admission-control voice max-airtime-percent 9 admission-control voice reserved-for-roam-percent 8 accelerated-multicast stream-threshold 15 nx9500-6C8809(config-radio-qos-test)#
rfs4000-229D58(config-radio-qos-test)#show context radio-qos-policy test service admission-control across-reassoc rfs4000-229D58(config-radio-qos-test)#
rfs4000-229D58(config-radio-qos-test)#no service admission-control across-reassoc
rfs4000-229D58(config-radio-qos-test)#show context radio-qos-policy test rfs4000-229D58(config-radio-qos-test)#
