Configures user-account lockout and unlock parameters. Use this option to configure the maximum number of consecutive, failed login attempts allowed before an account is locked out, and the duration of lockout.
passwd-entry role [device-provisioning-admin|helpdesk|monitor|network-admin|security-admin| superuser|system-admin|vendor-admin|web-user-admin] max-fail <1-100> lockout-time <0-600>
| passwd-entry role [device-provisioning-admin|helpdesk| monitor| network-admin| security-admin| superuser|system-admin|vendor-admin| web-user-admin] max-fail <1-100> lockout-time <0-600> | Configures user-role based account lockout criteria
When configured, the lockout is individually applied to each account within the specified role/roles. For example, consider the ‘monitor‘ role having two users: ‘user1‘ and ‘user2‘. The max-fail and lockout-time is set at ‘5‘ attempts and ‘10‘ minutes respectively. In this scenario, user2 makes 5 consecutive, failed login attempts, and the user2 account is locked out for 10 minutes. However, during this lockout time the user1 account remains active. Note: In the event-system-policy context, enable
‘login-lockout‘ and ‘login-unlocked‘ event notification to trigger e-mail or
syslog notification to users on occurrence of the login-lockout and login-unlock
events. For more information, see event.
rfs4000-6DB5D4(config-management-policy-default)#passwd-retry role monitor max-fail 5 lockout-time 10
rfs4000-6DB5D4(config-management-policy-default)#show con management-policy default no telnet no http server https server ssh user admin password 1 979cfb9288837ee26d74d07b5ea328fd0e9a2b55cf5104649c2b496cc94e7003 role superuser access all passwd-retry role monitor max-fail 2 lockout-time 5 snmp-server community 0 private rw snmp-server community 0 public ro snmp-server user snmptrap v3 encrypted des auth md5 0 admin123 snmp-server user snmpmanager v3 encrypted des auth md5 0 admin123 rfs4000-6DB5D4(config-management-policy-default)#
| no | Removes the user-account lockout and unlock parameters configured here |
