Creates a permit rule that marks packets (from a specified source IP and/or to a specified destination IP) for forwarding. You can also use this command to modify an existing permit rule.
Use a decimal value representation to implement a permit/deny designation for a packet. The command set for IP ACLs provides the hexadecimal values for each listed EtherType. Use the decimal equivalent of the EtherType listed for any other EtherType.permit [<NETWORK-SERVICE-ALIAS-NAME>|dns-name|icmp|ip|proto|tcp|udp]
permit <NETWORK-SERVICE-ALIAS-NAME> [<SOURCE-IP/MASK>|<NETWORK-GROUP-ALIAS-NAME>|
any|from-vlan <VLAN-ID>|host <SOURCE-HOST-IP>] [<DEST-IP/MASK>|any|host <DEST-HOST-IP>|
<NETWORK-GROUP-ALIAS-NAME>] (log,mark [8021p <0-7>|dscp <0-63>],rule-precedence <1-5000>)
{(rule-description <LINE>)}
permit dns-name [contains|exact|suffix]permit dns-name [contains|exact|suffix]
permit dns-name [contains|exact|suffix] <WORD> (log,rule-precedence <1-5000>)
permit dns-name exact <WORD> (log,mark [8021p <0-7>|dscp <0-63>],rule-precedence <1-5000>)
permit icmp [<SOURCE-IP/MASK>|<NETWORK-GROUP-ALIAS-NAME>|any|from-vlan <VLAN-ID>|
host <SOURCE-HOST-IP>] [<DEST-IP/MASK>|<NETWORK-GROUP-ALIAS-NAME>|any|host <DEST-HOST-IP>]
(<ICMP-TYPE> <ICMP-CODE>,log,rule-precedence <1-5000>) {(rule-description <LINE>)}
permit ip [<SOURCE-IP/MASK>|<NETWORK-GROUP-ALIAS-NAME>|any|from-vlan <VLAN-ID>|
(log,rule-precedence <1-5000>) {(rule-description <LINE>)}
permit proto [<PROTOCOL-NUMBER>|<PROTOCOL-NAME>|eigrp|gre|igmp|igp|ospf|vrrp]
[<SOURCE-IP/MASK>|<NETWORK-GROUP-ALIAS-NAME>|any|from-vlan <VLAN-ID>|host <SOURCE-HOST-IP>]
[<DEST-IP/MASK>|<NETWORK-GROUP-ALIAS-NAME>|any|host <DEST-HOST-IP>] (log,rule-precedence <1-5000>)
permit [tcp|udp] [<SOURCE-IP/MASK>|<NETWORK-GROUP-ALIAS-NAME>|any|from-vlan <VLAN-ID>|
host <SOURCE-HOST-IP>] [<DEST-IP/MASK>|<NETWORK-GROUP-ALIAS-NAME>|any|eq <SOURCE-PORT>|host <DEST-HOST-IP>|
range <START-PORT> <END-PORT>] [eq [<1-65535>|<SERVICE-NAME>|bgp|dns|ftp|ftp-data|gopher|https|ldap|nntp|ntp|pop3|
sip|smtp|ssh|telnet|tftp|www]|range <START-PORT> <END-PORT>] (log,rule-precedence <1-5000>)
<NETWORK-SERVICE-ALIAS-NAME> |
Applies this permit rule to packets based on service protocols and ports specified in the network-service alias
A network-service alias defines service protocols and ports to match. When used with an ACL, the network-service alias defines the service-specific components of the ACL permit rule. Note: For more information on configuring network-service alias, see alias.
<SOURCE-IP/MASK> |
Specifies the source IP address and mask (A.B.C.D/M) to match. Packets, matching the service protocols and ports specified in the network-service alias, received from the specified network are permitted. |
<NETWORK-GROUP-ALIAS-NAME> |
Applies a network-group alias to identify the
source IP addresses. Packets, matching the service protocols and ports
specified in the network-service alias, received from the addresses
identified by the network-group alias are permitted.
A network-group alias defines a single or a range of addresses of devices, hosts, and networks. When used with an ACL, the network-group alias defines the network-specific component of the ACL rule (permit/deny). |
any |
Specifies the source as any source IP address. Packets, matching the service protocols and ports specified in the network-service alias, received from any source are permitted. |
from-vlan <VLAN-ID> |
Specifies a single VLAN or a range of VLANs as
the match criteria. Packets, matching the service protocols and ports
specified in the network-service alias, received from the specified VLAN(s)
are permitted.
Note: Use this option with WLANs and port ACLs.
host <SOURCE-HOST-IP> | Identifies a specific host (as the source to
match) by its IP address. Packets, matching the service protocols and ports
specified in the network-service alias, received from the specified host are
permitted.
<DEST-IP/MASK> | Specifies the destination IP address and mask (A.B.C.D/M) to match. Packets, matching the service protocols and ports specified in the network-service alias, addressed to the specified network are permitted. |
any |
Specifies the destination as any destination IP address. Packets, matching the service protocols and ports specified in the network-service alias, addressed to any destination are permitted. |
host <DEST-HOST-IP> | Identifies a specific host (as the destination to
specified in the network-service alias, addressed to the specified host are
permitted.
<NETWORK-GROUP-ALIAS-NAME> | Applies a network-group alias to identify the
destination IP addresses. Packets, matching the service protocols and ports
specified in the network-service alias, destined for the addresses
log |
Logs all permit events matching this entry. If a source and/or destination IP address is matched (i.e. if any specified type of packet is received from a specified IP address and/or is destined for a specified IP address), an event is logged. |
mark [8021p <0-7>| dscp <0-63>] |
Specifies packets to mark
rule-precedence <1-5000> rule-description <LINE> |
The following keywords are recursive and common to all of the above parameters:
permit dns-name [contains|exact (mark)|suffix] <WORD> (log,rule-precedence <1-5000>)
dns-name | Applies this permit rule to packets based on dns-names specified in the network-service |
contains | Matches any hostname which has this DNS label. (for example, *.test.*) |
exact | Matches an exact hostname as specified in the network-service |
syffix | Matches any hostname as suffix (for example, *.test) |
<WORD> | Identifies a specific host (as the source to match) by its domain name. Packets, matching the service protocols and ports specified in the network-service alias, received from the specified host are forwarded. |
log | Logs all permit events matching this dns entry. If a dns-name is matched an event is logged. |
rule-precedence <1-5000> rule-description <LINE> | The following keywords are recursive and common
permit icmp [<SOURCE-IP/MASK>|<NETWORK-GROUP-NAME>|any|from-vlan <VLAN-ID>|
host <SOURCE-HOST-IP>] [<DEST-IP/MASK>|<NETWORK-GROUP-NAME>|any|host <DEST-HOST-IP>]
icmp |
Applies this permit rule to ICMP packets only |
<SOURCE-IP/MASK> |
Specifies the source IP address and mask (A.B.C.D/M) to match. ICMP packets received from the specified sources are permitted. |
source IP addresses. ICMP packets received from the addresses identified by
any |
Specifies the source as any IP address. ICMP packets received from any source are permitted. |
the match criteria. ICMP packets received from the VLANs identified here are
permitted.
ACLs.
match) by its IP address. ICMP packets received from the specified host are
permitted.
<DEST-IP/MASK> |
Specifies the destination IP address and mask (A.B.C.D/M) to match. ICMP packets addressed to specified destinations are permitted. |
Applies a network-group alias to identify the destination IP addresses. ICMP packets destined for addresses identified by the network-group alias are permitted.
any |
Specifies the destination as any IP address. ICMP packets addressed to any destination are permitted. |
match) by its IP address. ICMP packets addressed to the specified host are
permitted.
<ICMP-TYPE> |
Defines the ICMP packet type For example, an ICMP type 0 indicates it is an ECHO REPLY, and type 8 indicates it is an ECHO. |
<ICMP-CODE> |
Defines the ICMP message type For example, an ICMP code 3 indicates "Destination Unreachable", code 1 indicates "Host Unreachable", and code 3 indicates "Port Unreachable." Note: After specifying the source and destination IP
address(es), the ICMP message type, and the ICMP code, specify the action
taken in case of a match.
log |
Logs all permit events matching this entry. If a source and/or destination IP address is matched (i.e. a ICMP packet is received from a specified IP address and/or is destined for a specified IP address), an event is logged. |
ip |
Applies this permit rule to IP packets only |
<SOURCE-IP/MASK> |
Specifies the source IP address and mask (A.B.C.D/M) to match. IP packets received from the specified networks are permitted. |
Applies a network-group alias to identify the source IP addresses. IP packets received from the addresses identified by the network-group alias are permitted.
any |
Specifies the source as any source IP address. IP packets received from any source are permitted. |
Specifies a single VLAN or a range of VLANs as the match criteria. IP packets received from the specified VLANs are permitted.
Identifies a specific host (as the source to match) by its IP address. IP packets received from the specified host are permitted.
<DEST-IP/MASK> |
Specifies the destination IP address and mask (A.B.C.D/M) to match. IP packets addressed to the specified networks are permitted. |
any |
Specifies the destination as any destination IP address. IP packets addressed to any destination are permitted. |
Identifies a specific host (as the destination to match) by its IP address. IP packets addressed to the specified host are permitted.
Applies a network-group alias to identify the source IP addresses. IP packets destined for addresses identified by the network-group alias are permitted.
log |
Logs all permit events matching this entry. If a source and/or destination IP address is matched (i.e. a IP packet is received from a specified IP address and/or is destined for a specified IP address), an event is logged. |
proto |
Configures the ACL for additional protocols Additional protocols (other than IP, ICMP, TCP, and UDP) must be configured using this parameter |
<PROTOCOL-NUMBER> |
Filters protocols using their IANA protocol number
<PROTOCOL-NAME> |
Filters protocols using their IANA protocol name
eigrp |
Identifies the EIGRP protocol (number 88) EIGRP enables routers to maintain copies of neighbors‘ routing tables. Routers use this information to determine the fastest route to a destination. When a router fails to find a route in its stored route tables, it sends a query to neighbors who in turn query their neighbors till a route is found. EIGRP also enables routers to inform neighbors of changes in their routing tables. |
gre |
Identifies the GRE protocol (number 47) GRE is a tunneling protocol that enables transportation of protocols (IP, IPX, DEC net, etc.) over an IP network. GRE encapsulates the packet at the source and removes the encapsulation at the destination. |
igmp |
Identifies the IGMP protocol (number 2) IGMP establishes and maintains multicast group memberships to interested members. Multicasting allows a networked computer to send content to multiple computers who have registered to receive the content. IGMP snooping is for listening to IGMP traffic between an IGMP host and routers in the network to maintain a map of the links that require multicast streams. Multicast traffic is filtered out for those links which do not require them. |
igp |
Identifies any private internal gateway (primarily used by CISCO for their IGRP) (number 9) IGP enables exchange of information between hosts and routers within a managed network. The most commonly used IGP protocols are: RIP and OSPF |
ospf |
Identifies the OSPF protocol (number 89) OSPF is a link-state IGP. OSPF routes IP packets within a single routing domain (autonomous system), like an enterprise LAN. OSPF gathers link state information from neighbor routers and constructs a network topology. The topology determines the routing table presented to the Internet Layer which makes routing decisions based solely on the destination IP address found in IP packets. |
vrrp |
Identifies the VRRP protocol (number 112) VRRP allows a pool of routers to be advertized as a single virtual router. This virtual router is configured by hosts as their default gateway. VRRP elects a master router, from this pool, and assigns it a virtual IP address. The master router routes and forwards packets to hosts on the same subnet. When the master router fails, one of the backup routers is elected as the master and its IP address is mapped to the virtual IP address. |
<SOURCE-IP/MASK> |
Specifies the source IP address and mask (A.B.C.D/M) to match. Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) received from the specified sources are permitted. |
Applies a network-group alias to identify the source IP addresses. Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) received from the sources defined in the network-group alias are permitted.
any |
Specifies the source as any IP address. Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) received from any source are permitted. |
Specifies a single VLAN or a range of VLANs as the match criteria. Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) received from the VLANs identified here are permitted.
Identifies a specific host (as the source to match) by its IP address. Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) received from the specified host are permitted.
<DEST-IP/MASK> |
Specifies the destination IP address and mask (A.B.C.D/M) to match. Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) addressed to the specified destinations are permitted. |
any |
Specifies the destination as any destination IP address. Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) addressed to any destination are permitted. |
Identifies a specific host (as the destination to match) by its IP address. Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) addresses to the specified host are permitted.
Applies a network-group alias to identify the destination IP addresses. Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) addressed to the destinations identified in the network-group alias are permitted.
After specifying the source and destination IP address(es), specify the action taken in case of a match. |
log |
Logs all permit events matching this entry. If a source and/or destination IP address is matched (i.e. a packet (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) is received from a specified IP address and/or is destined for a specified IP address), an event is logged. |
host <DEST-HOST-IP>|range <START-PORT> <END-PORT>] [eq [<1-65535>|<SERVICE-NAME>|bgp|dns|ftp|
ftp-data|gopher|https|ldap|nntp|ntp|pop3|sip|smtp|ssh|telnet|tftp|www]|range <START-PORT>
<END-PORT>] (log,rule-precedence <1-5000>) {(rule-description <LINE>)}
tcp |
Applies this permit rule to TCP packets only |
udp |
Applies this permit rule to UDP packets only |
<SOURCE-IP/MASK> |
This keyword is common to the ‘tcp‘ and ‘udp‘ parameters. Specifies the source IP address and mask (A.B.C.D/M) to match. TCP/UDP packets received from the specified sources are permitted. |
This keyword is common to the ‘tcp‘ and ‘udp‘ parameters. Applies a network-group alias to identify the source IP addresses. TCP/UDP packets received from the VLANs identified here are permitted.
any |
This keyword is common to the ‘tcp‘ and ‘udp‘ parameters. Specifies the source as any source IP address. TCP/UDP packets received from any source are permitted. |
This keyword is common to the ‘tcp‘ and ‘udp‘ parameters. Specifies a single VLAN or a range of VLANs as the match criteria. TCP/UDP packets received from the VLANs identified here are permitted.
Identifies a specific host (as the source to match) by its IP address. TCP/UDP packets received from the specified host are permitted.
<DEST-IP/MASK> |
This keyword is common to the ‘tcp‘ and ‘udp‘ parameters. Sets the destination IP address and mask (A.B.C.D/M) to match. TCP/UDP packets addressed to the specified destinations are permitted. |
any |
This keyword is common to the ‘tcp‘ and ‘udp‘ parameters. Specifies the destination as any destination IP address. TCP/UDP packets received from any destination are permitted. |
eq <SOURCE-PORT> |
Identifies a specific source port
Identifies a specific host (as the destination to match) by its IP address. TCP/UDP packets addressed to the specified host are permitted.
This keyword is common to the ‘tcp‘ and ‘udp‘ parameters. Applies a network-group alias to identify the destination IP addresses. TCP/UDP packets destined to the addresses identified in the network-group alias are permitted.
eq [<1-65535>| <SERVICE-NAME>| |bgp|dns|ftp| ftp-data|gopher| https|ldap|nntp|ntp| pop3|sip|smtp| ssh|telnet| tftp|www] |
Identifies a specific destination or protocol port to match
range <START-PORT> <END-PORT> |
Specifies a range of destination ports
log |
Logs all permit events matching this entry. If a source and/or destination IP address or port is matched (i.e. a TCP/UDP packet is received from a specified IP address and/or is destined for a specified IP address), an event is logged. |
The following keywords are recursive and common to all of the above:
Use this command to permit traffic between networks/hosts based on the protocol type selected in the access list. The following protocols are supported:
IP
ICMP
ICP
UDP
PROTO (any Internet protocol other than TCP, UDP, and ICMP)
The last ACE in the access list is an implicit deny statement.
Whenever the interface receives the packet, its content is checked against all the ACEs in the ACL. The packet is allowed or denied based on the ACL configuration.
Filtering on TCP or UDP allows you to specify port numbers as filtering criteria.
Select ICMP to allow/deny packets. Selecting ICMP filters ICMP packets based on ICMP type and code.
The log option is functional only for router ACL‘s. The log option displays an informational logging message about the packet matching the entry sent to the console.nx9500-6C8809(config-ip-acl-test)#permit ip 172.16.10.0/24 any log rule-precedence 750
nx9500-6C8809(config-ip-acl-test)#permit tcp 172.16.10.0/24 any log rule-precedence 800
nx9500-6C8809(config-ip-acl-test)#show context ip access-list test permit ip 172.16.10.0/24 any log rule-precedence 750 permit tcp 172.16.10.0/24 any log rule-precedence 800 nx9500-6C8809(config-ip-acl-test)#
no |
Removes a specified IP permit access rule |
alias |
Creates and configures aliases (network, VLAN, service, etc.) |
