default-information
Controls the distribution of default
route information. Use the command to advertise a default route in the routing table.This option is
disabled by default. When enabled, the default route becomes a distributed
route.
- Access Points — AP 7161, AP 7502, AP-7522,
AP 7532, AP 7562, AP 7602, AP 7622, AP-8163, AP-8432, AP-8533
- Wireless Controllers — RFS 4000
Syntax
default-information originate {always|metric|metric-type}
default-information originate {always|metric <0-16777214>|metric-type [1|2]}
{(metric <0-16777214>|metric-type [1|2])}
Parameters
originate |
Originates default route information. Enabling this feature makes the
default route a distributed route. This option is disabled by
default. |
always |
Optional. Always distributes default route information (will continue to
advertise default route information even if that information has been
removed from the routing table for some reason). This option is disabled by
default. |
metric <0-16777214> |
This is a recursive parameter and can be optionally configured along
with the metric-type option.
- metric
<0-16777214> – Optional. Specifies OSPF metric value for
redistributed routes (this value is used to generate the default
route)
- <0-16777214> – Specify a value from 0 - 16777214.
metric-type [1|2] |
with the metric option.
- metric-type [1|2] –
Optional. Sets OSPF exterior metric type for redistributed routes
(this information is advertised with the OSPF routing domain)
- 1 – Sets OSPF
external type 1 metrics
- 2 – Sets OSPF
external type 2 metrics
nx9500-6C8809(config-profile default-rfs4000-router-ospf)#default-information
originate metric-type 2 metric 1
nx9500-6C8809(config-profile default-rfs4000-router-ospf)#show context
router ospf
area 0.0.0.4
auto-cost reference-bandwidth 1
default-information originate metric 1 metric-type 2
