This section lists the power accessories that are compatible with the 802.11ax access points.
All power cables and accessories must be purchased separately. Use the power accessory part number provided in the following tables to purchase the correct power accessory for your access point.
You should check End of Sale announcements regularily so you have access to the latest equipment.Part Number and Description |
AP302W |
AP305C/CX |
AP410C |
AP510C/CX |
AP3000/X |
AP4000 | AP5010 | |
10033 Power Cord, 10A,CEE 7/7,IEC320-C13,250V, 0.75MMSQ (for EU and Korea) |
10034 Formerly: AH-ACC-PW-CBL-UK Power Cord, 10A,BS1363, IEC320-C13, 250V, 0.75MMSQ (for UK) |
10036 Power Cord, 10A, AS3112, IEC320-C13, 250V, 0.75MMSQ (for AU) |
10043 Formerly: AH-ACC-PW-CBL-EU 6 ft. universal power cord with European Union plug |
10061 Formerly: AH-ACC-PW-CBL-US Power Cord, 10A,NEMA 5-15P, IEC320-C13, 125V, 18AWG (for US) |
10062 Formerly: AH-ACC-PW-CBL-JP Power Cord, 12A, JISC8303, IEC320-C13, 125V, 1.25MMSQ (for Japan) |
10089 Formerly: AH-ACC-PW-CBL-AU 6 ft. universal power cord with Australia plug |
37215 PWR12VDC, 2A, 2.5mm x 5.5mm connector |
37219 PWR 12VDC, 3A, 2.5mm x 5.5mm connector |
PD-3501G-ENT Indoor single port 802.3af compliant mid span |
AH-ACC-PW-30W 30W power adapter (12VDC, 2.5A) |
AH-ACC-PW-CBL-KR 6 ft. universal power cord with Korea plug |
PD-9001GO-ENT Outdoor 802.3at compliant PoE single port mid span |
PD-9001GR-ENT Indoor 802.3at compliant single port mid span |
The following table shows power cord cables and their corresponding outdoor access points. You use this information when you order a power cable.
Part Number and Description | AP460C, AP460S6C, and AP460S12C | AP5050D/U |
