Outdoor Wall Installation Using ACC-MBO-KT-AX
Adapter
Details about ACC-MBO-KT-AX
adapter and wall brackets that can be used with the adapter for wall
installation.
You can install the AP460C, AP460S6C,
or AP460S12C outdoor access points to an outdoor wall or a
flat surface using the ACC-MBO-KT-AX adapter. The adapter is used in combination with
the KT-147407-02 bracket parts and the KT-150173-01 extension arm.
The KT-147407-02 bracket parts and
the KT-1501730-01 extension arm must be purchased separately.
For detailed installation instructions, refer to the following procedures:
