Use the MBO-ART02 articulating
mounting bracket with the WS-MBO-POLE01 accessory for pole installations.
The MBO-ART02 wall mount bracket is End of Sale (EOS) as of January,
2023. It is replaced by the MBO-ART03 bracket.
For more information, see End of Sale and End Service Life.
The following hardware is required to install the MBO-ART02 accessory with
the WS-MBO-POLE01 bracket:
- One WS-MBO-POLE01
bracket
- Four stainless steel (SS) M4
screws with M4 split washers, and M4 hex nuts
- One MBO-ART02 articulating
mounting bracket
- Two stainless steel cable
clamps
- Four M4 SEMS screws
The MBO-ART02 bracket is used with outdoor access points.
Line up the smaller end of
MBO-ART02 on the attachment holes on the WS-MBO-POLE01 bracket.
Insert four M4 screws from the ART02 side and put on the split washers and hex
nuts from the POLE01 side.
Tighten the screws and hex nuts to 13.5 inch-lbs.
Use two stainless steel cable clamps to attach the POLE01 bracket to a
pole.
Torque the cable clamp screws to 13.5 inch-lbs.
To attach the access point to the larger end of the ART02 bracket, line up the
bracket holes against the mounting holes on the back of the access point.
Provide two stainless-steel M6 x
13 mm screws or bolts and two stainless-steel split washers, and put the split
washers on the screws.
Line up the two M6 holes in the AP360i/e, AP460i/e, AP560i, or AP560h access point with the two M6 holes in the large
side of the MBO-ART02 bracket.
Insert an M6 screw or
split-washer into the M6 hole and thread it until they are tight.
Torque the screws to 33 inch-lbs.
Adjust the black plastic bracket arm left to right as desired.
Insert the M4 locking bolt into the closest lock hole in the bracket that
aligns with the closest lock holes in the black plastic arm.
Thread a hex nut onto the bold.
Torque the nut to 13.5 inch-lbs.
Adjust the access point's downward tilt and insert the M4 locking bolt in the
appropriate hole and attach the hex nut.
The downward tilt must not be more than +/- 25° vertical tilt to prevent
water entry.
Attach the safety hanger strap as per the local code.
Results
When the installation is complete, the access point glands
must have a drip loop in each LAN cable and must be located on the lower side for AP560i and AP560h.
