| Section | Description |
| 11.ax Access Points and Mounting Accessory Usage Options | Updated for AP5020 |
| Power Accessories Matrix | |
| Indoor Mounting Accessory Compatibility with Access Points |
| Power Accessories Matrix | Updated for End of Sale , AP5010, AP3000, AP3000X, AP4000, AP5050D and AP5050U. |
| Install the Access Point on a Pole Using AH-ACC-STRP-MRN Accessory | Removed restriction regarding freezer usage. Documentation error. |
| Ethernet Cap Accessory Information | Added ACC-3000-ETH-CAP, a cable cover for AP3000 or AP3000X to hide Ethernet Port and Ethernet cable. |
Added support for the AP3000 and AP3000X access points. The AP3000 and AP3000X access points are Wi-Fi 6E tri-radio access points with support for multiple Extreme Networks operating systems. They offer an improved network experience for high density, indoor environments. |
| Outdoor Mounting Accessory Compatibility with Access Points | The MBO-ART03 Articulating Mounting Bracket bracket replaces the
ART02 bracket. It is a unistrut mounting bracket for use outdoors
and it has the following features:
| Install the Access Point on a Wall with the MBO-ART03 Articulating Mounting Bracket | You can use the MBO-ART03 Articulating Mounting Bracket when you install your access point on an outside wall. |
| Install the Access Point on a Wall Using ACC-MBOKT-AX Adapter and MBO-ART03 Articulating Mounting Bracket |
Use the MBO-ART03 Articulating Mounting Bracket articulating mounting bracket with the ACC-MBO-KT-AX Adapter for wall installations. |
| Install the Access Point on a Unistrut Structure Using the MBO-ART03 Articulating Mounting Bracket |
Use the MBO-ART03 Articulating Mounting Bracket with a unistrut structure. |
| Install the Access Point on a Pole | Use the KT-147407-02 and MBO-ART03 Articulating Mounting Bracket when you install your access point on an outside pole. |
| 11.ax Access Points and Mounting Accessory Usage Options | Added support for the AP5050D and the AP5050U outdoor access points. |
