Install the AP305C/CX Access Point on a
15/16 in. Wide Ceiling Rail Using ACC-BKT-TB-NF Adapter
The AP305C/CX access point can be mounted on a 15/16 in. wide ceiling rail
using the ACC-BKT-TB-NF adapter, when the ceiling tile protrudes below the T-bar.
The AP305C/CX access point comes with in-built clips in the back of the access
point that attach directly on to the -NF adapter, eliminating the need for the -TB
accessory.
Remove the ceiling tiles.
Using the adapter guide on the
top half of the ACC-BKT-TB-NF adapter, align and attach the -NF on to the
ceiling rail.
Callout
Description
1
Adapter guide for ceiling rail attachment
2
Adapter end
3
Indent for - NF second part attachment
4
Adapter tabs
Slide the other part of the
-NF adapter onto the half attached to the ceiling rail.
When the adapter parts are
attached properly, the adapter ends will line up after the two halves have
snapped together.
Align the built-in clips on the
AP305C/CX access point against the -NF adapter end.
Rotate the access point clockwise and attach it to the -NF adapter until it
clicks into place.
Plug the RJ45 connector plug into ETH or ETH0, RJ45 connector receptacle on the
access point.
Attach the Ethernet port cap to the access point Ethernet port.
