Indoor Mounting Accessory Compatibility with Access Points
Details about indoor mounting accessory part number and compatibility information with 802.11ax access points.
Table 1. Access point compatibility
Mounting accessory P/N
(Indoor)
Description Indoor AP
AP305C/CX
AP410C
AP510C/CX
AP650/X
AP4000
AP5010
AP3000/X
AP5020
AH-ACC-BKT-AX-IL Mounting bracket for Interlude (9/16 wide T-bar with protrusion) ceilings ✓ ✓ ✓ ✓ ✓ ✓
AH-ACC-BKT-AX-SL Mounting bracket for Silhouette ceilings (ceiling grid with 1/8 in. or 1/4 in. bottom opening) ✓ ✓ ✓ ✓ ✓ ✓
AH-ACC-BKT-AX-TB Mounting bracket for Prelude ceilings (15/16 in. ceiling grid), Suprafine ceilings (9/16 in. ceiling grid), and walls ✓ ✓ ✓ ✓ ✓ ✓
ACC-BKT-AX-TBW Mounting bracket for 1.5 inch wide T-bars (with varying thickness from 3.175 mm to 6.350 mm) with flush ceiling tiles ✓ ✓ ✓ ✓ ✓
AH-ACC-BKT-AX-WL Mounting bracket for direct-to-wall installations ✓ ✓ ✓ ✓ ✓ ✓
ACC-BKT-AX-JB Junction box or wall mounting for indoor access points ✓ ✓ ✓ ✓ ✓ ✓
ACC-BKT-AX-BEAM Beam mounting for indoor access points ✓ ✓ ✓ ✓ ✓ ✓
ACC-BKT-AX-WNGADAPT Adapter bracket for cloud access points to use with WiNG access point mounting plate (37201) ✓ ✓ ✓ ✓ ✓ ✓
