| Quantity | Item |
| 1 | Access point |
| 1 | MBO-ART03 articulating mounting bracket |
| 6 |
M6 hex-head screws Two M6 hex-head screws for attaching the bracket and the access point. Four M6 hex-head screws for attaching the bracket to the wall. |
| 2 |
Long M6 hex screws and nuts to lock each axis. |
You also need a torque wrench and tool that matches the nuts for the M6 hex screws.
Install the access point to a wall so it is secure and your customers can easily access your wireless network.
