802.11ax and Cloud Access Points
> Additional Help and Support
Published February 2024
Preface
New in this Guide
11.ax Access Points and Mounting Accessory Usage Options
Indoor Mounting Accessory Compatibility with Access Points
Outdoor Mounting Accessory Compatibility with Access Points
Power Accessories Matrix
Ethernet Cap Accessory Information
Indoor Mounting Accessory Installation Instructions
Position the Access Point before Installation
Install the Access Point on a 9/16 in. Wide Ceiling Using AH-ACC-BKT-AX-IL Accessory
Install the Access Point on a 9/16 in. Wide Ceiling Rail Using AH-ACC-BKT-AX-TB Accessory and AH-ACC-BKT-916-KIT Adapter
Install the AP305C/CX Access Point on a Flat 9/16 in. Wide Ceiling Rail Using AH-ACC-BKT-916-KIT Adapter
Install the Access Point on a Ceiling Grid With a Bottom Opening Using AH-ACC-BKT-AX-SL Accessory
Install the Access Point on a 15/16 in. Wide Ceiling Rail Using AH-ACC-BKT-AX-TB Accessory and ACC-BKT-TB-NF Adapter
Install the AP305C/CX Access Point on a 15/16 in. Wide Ceiling Rail Using ACC-BKT-TB-NF Adapter
Install the Access Point on a Wall or a Solid Ceiling Using AH-ACC-BKT-AX-TB Accessory
Install the Access Point on a T-Bar Using ACC-BKT-AX-TBW Accessory
Install the Access Point Directly on a Wall Using AH-ACC-BKT-AX-WL Bracket
AH-ACC-BKT-AX-WL Bracket Template
Install the Access Point on a Junction Box Using ACC-BKT-AX-JB Accessory
Install the Access Point on a Beam Using ACC-BKT-AX-BEAM Accessory
Install an Indoor Access Point on a Concrete Wall Using WNGADAPT Bracket on an Existing 37201 Metal Bracket
Lock the Indoor Access Point after Installation
Outdoor Mounting Accessory Installation Instructions
Install the Access Point on a Pole Using AH-ACC-STRP-MRN Accessory
Install the Access Point on a Flat Surface Using AH-ACC-BKT-ASM Accessory
Install the Access Point on a Unistrut Structure Using the MBO-ART03 Bracket
Outdoor Wall Installation Using ACC-MBO-KT-AX Adapter
Install the Access Point on a Wall Using ACC-MBO-KT-AX Adapter and KT-147407-02 Bracket Parts
Install the Access Point on a Wall Using ACC-MBO-KT-AX Adapter, KT-147407-02 Bracket Wall Parts, and KT-150173-01 Extension Arm
Install the Access Point on a Wall Using ACC-MBO-KT-AX Adapter and MBO-ART02 Articulating Mounting Bracket
Install the Access Point on a Wall With the MBO-ART03 Bracket
Install the Access Point on a Wall Using ACC-MBO-KT-AX Adapter and MBO-ART03 Articulating Mounting Bracket
Outdoor Pole Installation Using ACC-MBO-KT-AX Adapter
Install the Access Point on a Pole Using ACC-MBO-KT-AX Adapter and KT-147407-02 Bracket Parts
Install the Access Point on a Pole Using ACC-MBO-KT-AX Adapter, KT-147407-02 Bracket Parts, and KT-150173-01 Extension Arm
Install the Access Point on a Pole with the MBO-ART03 and KT-147407-02 Brackets
Install the Access Point on a Pole Using the WS-MBO-POLE01 and MBO-ART02 Accessories
Ground Connection
Use the information in the followinf sections if you need additional help.
