Install the Access Point on a Pole Using
ACC-MBO-KT-AX Adapter and KT-147407-02 Bracket Parts
Learn how to install an outdoor
access point on a pole using the -MBO adapter with the KT-147407-02 bracket
parts.
The following hardware is required for outdoor access point pole installation using
the -MBO adapter and KT-147407-02 bracket parts:
One outdoor access point
One ACC-MBO-KT-AX
adapter
Four M5 hex bolts
Flat part of the KT-147407-02
bracket
1-axis tilt part of the
Pole part of the KT-147407-02 bracket
Four M6 screws with split
washers and nuts
Four M6 screws
Two hex-head M12 stainless-steel bolts
Two hex-head M12 stainless-steel nuts
Two 0.5 in. wide stainless-steel cable clamps for pole mounting
The ACC-MBO-KT-AX adapter is used with outdoor access points to add a tilt to the
access point after installation. For pole installations, the -MBO adapter is used in
combination with all three KT-147407-02 bracket parts.
The cable glands must face down
when you install the access point on a pole.
KT-147407-02 bracket pole
part front view
part side view
Attach the ACC-MBO-KT-AX adapter
to the access point using four M5 bolts.
Torque the M5 bolts to 25 in-lbs.
Attach the flat part of the
KT-147402-02 bracket to the ACC-MBO-KT-AX adapter using four M6 screws, split
washers, and hex nuts.
Torque the bolts and nuts to 32 in-lbs.
Align the 1-axis tilt bracket
part inside the flat part of the KT-147407-02 bracket, and attach the flat
bracket to the 1-axis tilt bracket using four M6 screws.
Adjust the tilt and tighten the screws to a torque of 32 in-lbs.
Attach the KT-147407-02 pole part to the 1-axis tilt part using two M12 bolts
through the large bracket holes on 1-axist tilt part and the pole part.
Fasten the bolts using two M12
hex nuts and torque it to 22 ft-lbs..
Insert the 0.5 in. stainless-steel cable clamp through the large slots on the
pole bracket.
Position the cable clamps on the bracket around a pole.
Insert the ends of the cable
clamps around the pole and tighten the clamp screws to a torque of 14
in-lbs.
