Outdoor Mounting Accessory Compatibility with Access Points
Details about outdoor mounting accessory part number and compatibility information with 802.11ax access points.
Table 1. Access point compatibility
Part number Description Access point compatibility
Outdoor access points
AP460C, AP460S6C, and AP460S12C AP360i/e, AP460i/e, AP560i/AP560h, and AP5050D/AP5050U
Outdoor mounting accessory AH-ACC-STRP-MRN Outdoor access point stainless steel hose strap for 3 in. – 7 in. diameter pole ✓ ✓
AH-ACC-BKT-ASM Outdoor access point stainless steel wall bracket assembly ✓ —
ACC-MBO-KT-AX Adapter bracket for outdoor access point tilt ✓ —
KT-147407-02 Wall and pole mounting bracket with +/- 15-degrees 1-azis tilt ✓ (must be used with the -AX adapter bracket) ✓
KT-150173-01 Straight 12 inches extension arm ✓ (must be used with the -AX adapter bracket) ✓
WS-MBO-POLE01
Note:
The WS-MBO-POLE01 bracket is End of Sale (EOS) as of January, 2023.
For more information, see End of Sale and End Service Life.
Pole mounting bracket for MBO-ART02 bracket ✓ (must be used with the -AX adapter bracket.) ✓
MBO-ART03 Unistrut mounting bracket with +/- 80-degree (in 10-degree increments) 2-axis tilt and variable 7 inches to 10 inches extension ✓ (must be used with the -AX adapter bracket) ✓
MBO-ART02
Note:
The MBO-ART02 wall mount bracket is End of Sale (EOS) as of January, 2023. It is replaced by the MBO-ART03 bracket.
Wall mounting bracket with +/- 80-degree (in 20-degree increments) 2-axis tilt and 10 inches extension ✓ (must be used with the -AX adapter bracket.) ✓
