This procedure is not applicable for AP305C/CX access points, if you choose to use the integral bottom clips on the back of the access point. For mounting the AP305C/CX access points on a 9/16 in. wide T-bar, see Install the AP305C/CX Access Point on a Flat 9/16 in. Wide Ceiling Rail Using AH-ACC-BKT-916-KIT Adapter.
| Installation scenario | Installation option |
| Ceiling tiles are flat without any protrusion and the T-bar is flat without any central protrusion | Use the AH-ACC-BKT-AX-TB accessory by itself with the access point and on the ceiling grid |
| Ceiling tiles have protrusion (edge steps), but the T-bar does not have a central protrusion | Use the AH-ACC-BKT-AX-TB accessory with the AH-ACC-BKT-916-KIT adapter |
| T-bar has central protrusion | Use the AH-ACC-BKT-AX-IL accessory on the T-bar |
The AH-ACC-BKT-916-KIT adapter comes with four interlocking pieces of which only the two tall ones will be used.
To install an indoor access point on a 9/16 in. wide T-bar without central protrusion using the AH-ACC-BKT-AX-TB accessory and the AH-ACC-BKT-916-KIT adapter:
