Install an Indoor Access Point on a
Concrete Wall Using WNGADAPT Bracket on an Existing 37201 Metal Bracket
Details about ACC-BKT-AX-WNGADAPT
adapter bracket for cloud access points to use with WiNG access point mounting bracket
(37201).
For any indoor concrete wall installations, use the ACC-BKT-AX-WNGADAPT adapter
bracket parts with an existing 37201 metal bracket.
Warning
Do not use
the AH-ACC-BKT-AX-TB bracket for indoor concrete wall installations.
The 37201 metal mounting bracket ships with indoor WiNG access
points. If you do not have the 37201 metal bracket, order it
separately.
Attach the 37201 bracket to the wall before installing the WNGADAPT adapter. The
37201 main mounting bracket ships with the following items:
One 37201 main mounting
bracket
Two Philips pan-head
screws
Two screw-in anchors
For
concrete wall installations, you must provide screws and screw-in
anchors.
Use the metal mounting
bracket as a template and mark and drill two mounting holes.
The four bracket feet and
the engraved bracket arrows must be pointing up.
37201 main
mounting metal bracket
Attach the screw-in anchors
to the mounting holes.
Plastic screws and screw-in anchors are for
drywall and metal screws and screw-in anchors are for drywall or wood
wall installations.
For concrete wall installations, use a masonry
anchor which slips into a drilled hole and expands as the bolt is
tightened. Masonry anchors are not provided with the #37201
bracket.
Place the metal bracket over
the mounting holes and run the LAN cable through the large center hole on
the metal mounting bracket.
Attach the bracket using two
pan-head screws for drywall, wood wall, or metal installations.
Masonry
anchors have integral threaded studs. If you are attaching the 37201
bracket to a concrete wall, then the anchor studs must protrude through
the holes where a hex nut is tightened.
The WNGADAPT plate ships with two parts:
One WNGADAPT circular plastic
twist part
One WNGADAPT metal plate
With the WNGADAPT metal plate
engraved arrows pointing up, place the WNGADAPT metal plate over the 37201 metal
mounting bracket.
AX-BKT-WNGADAPT
bracket
Run the LAN cable through the
large center opening on the WNGADAPT plate.
Push the WNGADAPT metal plate
down on to the 37201 bracket until the metal plate clicks in place.
Line the plastic twist part
embossed dot against the red dot on the WNGADAPT metal plate.
Bring the LAN cable up
between the WNGADAPT metal plate and the plastic twist part.
Rotate the twist part clockwise
¼th of a turn until the locking pin on the WNGADAPT metal plate
clicks into place.
Line up the red dot on the rear of the access point against the red dot on the
plastic twist part.
Ensure that the access point center recess area aligns onto the plastic twist
center post.
Rotate the access point 1/6 of a
turn clockwise until it clicks into place.
Insert the LAN cable into the RJ45 connector on top of the access point.
If there is a LAN cable PoE,
the access point starts a boot cycle.
If desired, use an in-line
coupler, flat cable, and a cosmetic cap to attach the RJ45 cable onto the
indoor access points.
