Learn how to install an outdoor
access point on a pole using the -MBO adapter with KT-147407-02 bracket parts and the
KT-150173-01 extension arm.
The following hardware is required for outdoor access point pole installation using
the -MBO adapter, KT-147407-02 bracket parts, and KT-150173-01 extension arm:
- One outdoor access point
- One ACC-MBO-KT-AX
adapter
- Four M5 hex bolts
- Flat part of the KT-147407-02
bracket
- 1-axis tilt part of the
- Pole part of the KT-147407-02 bracket
- One KT-150173-01 extension arm
- Six M6 screws
- Four hex-head M12 stainless-steel bolts
- Four hex-head M12 stainless-steel nuts
- Two 0.5 in. wide stainless-steel cable clamps for pole mounting
Use the -MBO adapter in combination with the KT-147407-02 bracket parts and the
KT-150173-01 extension arm for pole installations.
The cable glands must face
down when you install the access point on a pole.
Attach the ACC-MBO-KT-AX adapter
to the access point using four M5 bolts.
Tighten the bolts to a torque of 25 in-lbs.
Attach the KT-147407-02 flat
part and the 1-axis tilt part.
Tighten the screws and nuts to a torque of 32 in-lbs.
Align the circular holes on one end of the KT-150173-01 extension arm against
the large holes on the 1-axis tilt bracket part.
Attach the KT-150173-01 extension arm to the 1-axis tilt bracket using two
hex-head M12 stainless-steel screws and two hex-head M12 stainless-steel
nuts.
Attach the KT-147407-02 pole part to the other end of the KT-150173-01
extension arm using two M12 screws and M12 hex-nuts.
Tighten the M12 bolts and nuts
to a torque of 22 ft-lbs.
Insert 0.5 in. stainless-steel cable clamps through the KT-147407-02 pole part
long slots.
Position the cable clamps around a pole.
Insert the ends of the cable
clamps around the pole and tighten the clamp screws to a torque of 14
in-lbs.
