Details about how to use the
AH-ACC-BKT-AX-WL bracket for direct-to-wall installations.
The following hardware is required for direct-to-wall installations:
- An indoor access point
- One AH-ACC-BKT-AX-WL bracket
- Three M3.5 screws and three
screw-in anchors, shipped with the -WL bracket
The AH-ACC-BKT-AX-WL bracket is for users who already have the -WL bracket. For new
wall installations, order either the -TB or -JB bracket.
Using the -WL bracket as a
template, mark and drill mounting holes on the wall.
Bring the LAN cable from the wall through the bracket hole.
Align the cable before
attaching the bracket to the wall.
A standard Ethernet cable can
be used if you do not mind the cable being visible. To hide the Ethernet
cable, a flat cable and a cable cap are required.
Attach the wall bracket to the
wall using three M3.5 screws and three screw-in anchors.
Align the access point red dot
against the three red dots on the -WL bracket.
Press and rotate the access
point clockwise about one-sixth turn until it locks into place on the
bracket.
Attach the Cat5e RJ45 cable to
the ETH0 port on AP305C/CX or the Cat6 RJ45 cable to the ETH0 or ETH1
port on all other indoor access points.
Place the cable cover over the Ethernet cable.
The cable cover will work only if you use a flat cable adapter.
