This procedure is not applicable for the AP305C/CX access points, if you choose to use the integral bottom clips on the back of the access point. For mounting the AP305C/CX access points on a 15/16 in. wide T-bar, see Install the AP305C/CX Access Point on a 15/16 in. Wide Ceiling Rail Using ACC-BKT-TB-NF Adapter.
If you use the AH-ACC-BKT-AX-TB accessory with a ceiling grid that is 15/16 in. wide and has a protruded ceiling tile, you must use the ACC-BKT-TB-NF adapter with the -TB accessory during installation.
The ACC-BKT-TB-NF adapter comes with two interlocking pieces.
To install an indoor access point on a 15/16 in. wide ceiling tile using the AH-ACC-BKT-AX-TB accessory and the ACC-BKT-TB-NF adapter:
