Outdoor Pole Installation Using ACC-MBO-KT-AX
Adapter
Details about ACC-MBO-KT-AX
adapter and pole brackets that can be used with the adapter for outdoor pole
installation.
You can install the AP460C, AP460S6C,
or AP460S12C outdoor access points to an outdoor pole using
the ACC-MBO-KT-AX adapter. The adapter is used in combination with the KT-147407-02
bracket parts and the KT-150173-01 extension arm.
The KT-147407-02 and the
KT-1501730-01 extension arm must be purchased separately.
For detailed installation instructions, refer to the following procedures:
