Learn how to safely ground the
access point using the grounding hardware.
The following hardware is required for ground connection:
An access point
One M4 ground screw
One star washer
One ground terminal
One ground wire
The installer must provide the
ground wire.
When you install the access point on an outdoor environment,
you must provide protective grounding to prevent the access point from damages and
failures.
Strip the insulation off one end
of the ground wire and attach the stripped wire to the ring terminal.
The best practice is to use
a 10 AWG electrical wire.
Attach the ground wire ring
terminal to the access point using the M4 ground screw assembly with the star
washer.
The star washer must be in
contact with both the ring terminal and the access point.
Ground connection on
the access point
Callout
Description
1
Ground terminal edge area
2
Ground terminal
3
10 AWG ground wire
4
M4 screw
5
Star washer
Tighten the screw to a torque of
12 in-lbs.
Connect the other end of the
ground wire to an appropriate earthing location.
