The following hardware is required to install your access point to a pole with the MBO-ART03 and KT-147407-02 brackets.
| Quantity | item |
| 1 | Access point. |
| 1 |
KT-147407-02 bracket. |
1 |
MBO-ART03 articulating mounting bracket. |
| 2 | M6 hex-head screws to attach the MBO-ART03 to the access point. |
| 2 |
M6 screws with nuts and washers to attach KT-147407-02 to the MBO-ART03. |
| 2 |
Long M6 Hex hex screws and nuts for providing an angular lock for each axis. |
| 2 | Cable clamps with a band of 0.5 in. (12.7 mm). Cable clamps must be purchased seperately as they are not included. |
| 1 | Torque wrench with sockets. |
| 1 | Flat head screwdriver. |
You can install your access point to a pole if you do not want to drill into a concret wall. With a pole, the access point coverage area can be greater because a pole is often higher than a wall.
