Install the Access Point on a 9/16 in.
Wide Ceiling Using AH-ACC-BKT-AX-IL Accessory
Learn how to install any indoor
access point on a 9/16 in. wide T-bar up to a 0.175 in. ceiling tile protrusion using
the AH-ACC-BKT-AX-IL accessory.
The following hardware is required to install the access point on an Interlude
ceiling (9/16 in. wide T-bar with protrusion):
An indoor access point
One AH-ACC-BKT-AX-IL
accessory bracket
The AH-ACC-BKT-AX-IL accessory is
used on 9/16 in. wide Interlude (9/16 wide T-bar with protrusion) ceiling rails. The
ceiling grid cross-section is printed on the back of the accessory for your
reference.
protrusion
Remove the ceiling tiles.
Place the bracket on the ceiling
rail in such a way that the accessory center is over the protrusion and the
metal hinges are between perpendicular and about one-eighth of a turn from the
sides of the ceiling rail.
Push up gently and rotate the
bracket clockwise until the hinges hook over the edge of the rail and the white
tabs click in place.
There are two white tabs in
the back of the accessory bracket that holds on to the ceiling rail in
place. Use your finger to pull and unhook one side of the white tab if you
want to remove the accessory from the ceiling rail.
Gently rotate the
bracket counterclockwise and if there is resistance, the other white tab
in the back of the accessory must also be released.
AH-ACC-BKT-AX-IL
accessory bracket
Call out
Description
1
Metal hinges on the AH-ACC-BKT-AX-IL bracket.
2
White tabs on the AH-ACC-BKT-AX-IL bracket.
3
Drawing of 9/16 in. ceiling grid, for your
reference.
When using a AP305C/CX or AP410C access point, attach the Ethernet port cap to the access point
Ethernet port.
