Learn how to install an outdoor
access point using the -MBO adapter and the MBO-ART02 articulating mounting
bracket.
![Note](images/note.png)
The MBO-ART02 wall mount bracket is End of Sale (EOS) as of January,
2023. It is replaced by the MBO-ART03 bracket.
For more information, see End of Sale and End Service Life.
The following hardware is required for outdoor access point wall installation
using the -MBO adapter and MBO-ART02 articulating mounting bracket:
- One outdoor access point
- One ACC-MBO-KT-AX
adapter
- Four M5 hex bolts
- One MBO-ART02 articulating
mounting bracket
- Six M6 hex-head screws
Attach the access point to a wall using the -MBO adapter with the MBO-ART02
articulating mounting bracket.
When using the MBO-ART02 articulating mounting bracket, set the maximum
downward tilt to less than 20 degrees to prevent water ingress.
Attach the ACC-MBO-KT-AX adapter
to the access point using four M5 bolts.
Torque the M5 bolts to 25 in-lbs.
Use the MBO-ART02 articulating mounting bracket as a template, mark and drill
four holes on the wall.
MBO-ART02 articulating mounting bracket wall holes template
Attach the larger face plate end
of the MBO-ART02 mounting bracket to the ACC-MBO-KT-AX adapter using two M6
hex-head screws.
Align the mounting holes on the ART02 bracket against the holes on the
wall.
Attach the ART02 bracket to the wall using four M6 hex-head screws.
