Install the Access Point on a Wall Using
ACC-MBO-KT-AX Adapter and KT-147407-02 Bracket Parts
Learn how to install an outdoor
access point using the ACC-MBO-KT-AX adapter with the KT-147407-02 bracket wall
parts.
The following hardware is required for outdoor access point wall installation using
the -MBO adapter and the KT-147407-02 bracket parts:
One outdoor access point
One ACC-MBO-KT-AX adapter
Four M5 hex bolts
Flat part of the KT-147407-02 bracket
1-axis tilt part of the KT-147407-02 bracket
Four M6 hex screws with split washer and hex nut
Four M6 headsize screws
Four M6 screws
All accessories must be purchased separately.
The ACC-MBO-KT-AX adapter is used with outdoor access points to add a tilt to the
access point after installation. For wall installations, the -MBO adapter is used in
combination with the KT-147407-02 bracket wall parts. The KT-47407-02 has three
bracket parts, two parts for wall installation and one part for pole
installation.
For pole installations, the ACC-MBO-KT-AX adapter is used in combination with the
KT-147407-02 bracket wall and pole parts.
bracket for outdoor access point tilt
KT-147407-02 bracket flat
part front view
part side view
1-axis tilt part front view
1-axis tilt part side view
Attach the ACC-MBO-KT-AX adapter
to the access point using four M5 bolts.
ACC-MBO-KT-AX adapter bracket attachment to an outdoor access
point
Torque the M5 bolts to 25 in-lbs.
Attach the flat part of the KT-147402-02 bracket to the ACC-MBO-KT-AX adapter
using four M6 screws, split washers, and hex nuts.
KT-147407-02 flat part
attachment to -AX adapter bracket
Torque the bolts to 45 in-lbs.
Using the 1-axis tilt bracket as a template, mark and drill four holes on a
wall or on a flat surface.
Attach the 1-axis tilt bracket to a wall or a flat surface using four M6
headsize screws.
Align the 1-axis tilt bracket part inside the flat part of the KT-147407-02
bracket, and attach the flat bracket to the 1-axis tilt bracket using four M6
screws.
Tilt the access point to a desired angle and tighten the four M6 screws to a
torque of 45 in-lbs.
The tilt bracket has +15 degrees to -15 degrees of tilt.
