Install the Access Point on a T-Bar Using
ACC-BKT-AX-TBW Accessory
The following hardware is required for installing the ACC-BKT-AX-TBW accessory on a
T-bar:
An indoor access point
One ACC-BKT-AX-TBW
Accessory
Two M3.5 screws (included in
the -TBW accessory)
The screws come with the
accessory and are partially attached in place.
You can use the ACC-BKT-AX-TBW
accessory for T-bar installation. The -TBW bracket is used for 1.5 inch wide T-bars with
varying thickness from 3.175 mm to 6.350 mm, with flush ceiling tiles.
The following
ceiling tile protrusions are accommodated by the -TBW mounting bracket:
If the T-bar is 0.25 inches thick, the -TBW bracket will only accommodate
flush ceiling tiles
If the T-bar is 0.1875 inches
thick, the -TBW bracket will accommodate flush ceiling tiles as well as
ceiling tiles with 0.062 inches protrusion
If the T-bar is 0.125 inches
ceiling tiles up to 0.125 inches protrusion
ACC-BKT-AX-TBW bracket T-bar side
Callout
Description
1
-TBW bracket plastic parts
2
-TBW bracket metal parts
3
Red on the bracket to align against the access point
Turn the -TBW accessory screws
in such a way that they do not extend past the plastic on the T-bar side.
Align the -TBW accessory metal
clips on a T-bar and rotate the metal clip about 1/6th turn clockwise
to attach the bracket to the T-bar.
Tighten the screws until either
resistance is noticed or the screw head bottoms on the -TBW accessory plastic
part.
Torque the screws to 1.0
in-lbs, and turn each screw 1 more complete turn clockwise.
access point side
Callout
Description
1
Screws for tightening to T-bar
Attach the access point to the
-TBW bracket by aligning the red dot on the bracket and the access point.
The bracket has a circular
tip that fits into the circular depression on the back of the access
point.
Press and rotate the access
point 1/6th turn
clockwise until it clicks into place on the bracket.
Attach the Cat5e RJ45 cable to
the ETH0 port on AP305C/CX or the Cat6 RJ45 cable to the ETH0 or ETH1
port on all other indoor access points.
If desired for aesthetics, place
the cable cover over the Ethernet cable.
