Install the Access Point on a Flat Surface
Using AH-ACC-BKT-ASM Accessory
Install the access point on a
vertical or horizontal outdoor flat surface using the AH-ACC-BKT-ASM
accessory.
The following hardware is required to install the access point to a flat surface:
An access point (AP460C, or AP460S6C, or AP460S12C)
AH-ACC-BKT-ASM wall accessory
(must be purchased separately)
Four shoulder M5 bolts
Four M5 mount screws and
screw-in anchors (must be provided by the installer)
Callout
Description
1
M5 bolt attachment holes
If you are mounting the access
point horizontally, ensure that the ports are facing down to reduce the chance of
water entering the chassis.
Using the ASM wall accessory as
a template, mark and drill four mounting holes on a flat surface.
The printed arrows on the accessory must be pointing up.
ASM accessory wall
mounting hole markings
Attach the ASM accessory to the
wall by using four M5 shoulder mounting screws.
Tip
The best
practice is to use screw-in anchors with the mounting screws on a wood
surface, and concrete anchors on a concrete surface.
Insert the M5 shoulder mounting
screws into the access point mounting holes.
Wall mounting
accessory M5 bolt holes
Torque the M5 shoulder mounting screws to 25 in-lbs.
Remove the two locking screws on the accessory.
ASM accessory locking
screws
The access point will not go onto the accessory if the locking screws are
not removed.
Insert the M5 bolt heads on the
access point into the large end of the accessory keyholes and slide the access
point down until the bolts rest in the narrow end of the keyholes.
Tighten the locking screws on
the ASM accessory to secure the access point.
