Install the Access Point on a Ceiling Grid
With a Bottom Opening Using AH-ACC-BKT-AX-SL Accessory
Learn how to install an indoor
access point on a 1/8 in. or ¼ in. Silhouette (ceiling grid with a bottom opening) using
the AH-ACC-BKT-AX-SL accessory.
The following hardware is required to install the access point on a 1/8 in. or ¼ in.
Silhouette (ceiling grid with a bottom opening) ceiling:
An indoor access point
One AH-ACC-BKT-AX-SL
accessory
The AH-ACC-BKT-AX-SL accessory is used on a silhouette ceiling with a 1/8 in. or a ¼
in. main beam reveal. The Silhouette (ceiling grid with bottom openings) ceiling
drawing is printed in the back of the accessory for your reference.
Ceiling grid with 1/8 in. or ¼ in. bottom openings
Remove the ceiling tiles.
Place the bracket on the ceiling
rail in such a way that the accessory metal hinges are almost perpendicular to
the sides of the ceiling rail with the ceiling rail over the center hole.
Lightly push onto to the ceiling
rail and rotate the accessory clockwise until the hinges hook over the edge of
the rail and the white tabs click in place.
There are two white tabs in
the back of the bracket that holds on to the ceiling rail. Use your finger
to pull and unhook one side of the white tab if you want to remove the
accessory from the ceiling rail.
Gently rotate the bracket
counterclockwise and if there is resistance, the other white tab in the
back of the accessory must also be released.
AH-ACC-BKT-AX-SL
accessory bracket
Call out
Description
1
Metal hinges on the AH-ACC-BKT-AX-SL bracket.
2
White tabs on the AH-ACC-BKT-AX-SL bracket.
3
Drawing of 1/8 in. or 1/4 in. ceiling grid, for your
reference.
Align the red dot on the back of
the access point against the accessory bracket red dot.
The accessory has a
circular tip that fits into the circular depression on the back of the
access point.
AH-ACC-BKT-AX-SL
accessory bracket circular tip
Call out
Description
1
AH-ACC-BKT-AX-SL bracket circular tip
Press and rotate the access
point clockwise until it locks into place on the accessory.
Plug the RJ45 connector plug into ETH or ETH0, RJ45 connector receptacle on the
access point.
When using a AP305C/CX or AP410C access point, attach the Ethernet port cap to the access point
Ethernet port.
